7 members (Guitplayer, klhansen, Otto Skorzeny, Phak1, CATMAN, Philipj, CharlieF),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,153 Posts1,056,847 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | Leonard said this in the gallery about his '37
"The rear end and the four link is now installed ( TCI said no one had ever tried putting a 4 link in a 1937 pickup truck but I should let them know how I did it!! YEA RIGHT! I'll let you guys know how to do it if anyone needs some help along the way ). The fuel cell is also installed."
I do not know what a 4 link and a fuel cell are? What are they used for? Who is TCI? Thanks, Martin | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | TCI is short for Total Cost Involved, the sell frames, custom suspension parts, and other restoration and modification parts. A four link is a suspension system that has four bars that join to the frame and axle in four places. The norm is a parallel four link like this: http://www.totalcostinvolved.com/productdet.cfmThe horizontal bar and forward mounts bolt/weld to the frame and the axle is welded into the perches at the other end of the rods. A fuel cell is a type of gas tank. Typically they are mounted between the rear frame rails where the spare tire goes. Here is an example from Summit Racing: http://store.summitracing.com/partdetail.asp?part=SUM-293215&view=1&N=700+150+-128260+Hope this helps, Drew | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Nice clear explanation. I will need Drew to explain to me how to rebuild the front suspension and disc brakes on the kit I got with no instructions. Just kidding, I have 1/2 installed but really don't know where the proportioning valve goes. On the front or rear brakes. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | ( TCI said no one had ever tried putting a 4 link in a 1937 pickup truck I don't think TCI would tell anyone that. They probably sell as many or more 4 link than anyone else. http://www.totalcostinvolved.com/vehicle.cfm
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its all a fading memory now unless I crawl under the 37 but it seems I had more than an "in and out" line going to my valve, more like two in and two out, where as the one in the link was just in and out..... Hmmm, I'm sure someone will help me "see clearly".
| | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | Thanks Everyone for the replies. I sure do get some good information here.
Sorry I don't know as much as I should but I'm getting there. | | |
