0 members (), 85 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
Leonard said this in the gallery about his '37
"The rear end and the four link is now installed ( TCI said no one had ever tried putting a 4 link in a 1937 pickup truck but I should let them know how I did it!! YEA RIGHT! I'll let you guys know how to do it if anyone needs some help along the way ). The fuel cell is also installed."
I do not know what a 4 link and a fuel cell are? What are they used for? Who is TCI?
The CPA, never under estimate the value;
especially when he's driving an old Chevy truck!
1947 Chevy 1/2-Ton Advance Design in the Gallery
1951 Chevrolet 3100
TCI is short for Total Cost Involved, the sell frames, custom suspension parts, and other restoration and modification parts.
A four link is a suspension system that has four bars that join to the frame and axle in four places. The norm is a parallel four link like this: http://www.totalcostinvolved.com/productdet.cfm
The horizontal bar and forward mounts bolt/weld to the frame and the axle is welded into the perches at the other end of the rods.
A fuel cell is a type of gas tank. Typically they are mounted between the rear frame rails where the spare tire goes. Here is an example from Summit Racing: http://store.summitracing.com/partdetail.asp?part=SUM-293215&view=1&N=700+150+-128260+
Hope this helps,
Drew
Nice clear explanation. I will need Drew to explain to me how to rebuild the front suspension and disc brakes on the kit I got with no instructions. Just kidding, I have 1/2 installed but really don't know where the proportioning valve goes. On the front or rear brakes.
I don't think TCI would tell anyone that. They probably sell as many or more 4 link than anyone else.
http://www.totalcostinvolved.com/vehicle.cfm
~Jim
Gazim, I dug up this diagram of where to put a proportioning valve:
http://www.chevyhiperformance.com/techarticles/71398_install_brake_proportioning_valve/photo_04.html
Aren't they used to adjust how much pressure goes to the rear brakes so that the front brakes do the bulk of the stopping?
Its all a fading memory now unless I crawl under the 37 but it seems I had more than an "in and out" line going to my valve, more like two in and two out, where as the one in the link was just in and out.....
Hmmm, I'm sure someone will help me "see clearly".
Thanks Everyone for the replies. I sure do get some good information here.
Sorry I don't know as much as I should but I'm getting there.
1951 Chevrolet 3100
