1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#462119 10/16/2008 7:44 PM
i thought of saving a little cash by using pressure treated ply wood for the floorboard. any advice?
philip t #462125 10/16/2008 8:10 PM
Plywood would suffice as a temporary fix but would most likely have some flex. I made up a sheet metal floor here. I have maybe 6-8 hours time into fabricating and looks fairly orginal. May be an option for you. Have fun and good luck
Dan
Chev4t6 #462228 10/17/2008 12:59 AM
I had a wood floor in my 46 when I got it. It worked OK but I don't think it saw much water here in So. Cal. I replaced it with an after market fiberglass one. It works fine.
If you want to save some money I'd say go with wood, at least until you can do something else.
George
46forme #462480 10/17/2008 4:27 PM
If you can find some scrap wood around a construction site I would say go for it.....but if you have to buy it you may have to buy a bigger piece than you need. So, use the money wisely and get a fiberglass one....OR if you have an old one to go by let a Heating and Air make you one in their sheet metal shop. I had one made not to long ago and it only cost me $25. I drilled the holes and it worked really nice......and if you "know someone" you can probably get it cheaper than that!
Do it once...do it right. Even if it takes longer.
Moderated by  ndkid275, Phak1
