| | | Forums66 Topics128,049 Posts1,055,638 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i thought of saving a little cash by using pressure treated ply wood for the floorboard. any advice? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Plywood would suffice as a temporary fix but would most likely have some flex. I made up a sheet metal floor here. I have maybe 6-8 hours time into fabricating and looks fairly orginal. May be an option for you. Have fun and good luck Dan | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I had a wood floor in my 46 when I got it. It worked OK but I don't think it saw much water here in So. Cal. I replaced it with an after market fiberglass one. It works fine. If you want to save some money I'd say go with wood, at least until you can do something else. George | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you can find some scrap wood around a construction site I would say go for it.....but if you have to buy it you may have to buy a bigger piece than you need. So, use the money wisely and get a fiberglass one....OR if you have an old one to go by let a Heating and Air make you one in their sheet metal shop. I had one made not to long ago and it only cost me $25. I drilled the holes and it worked really nice......and if you "know someone" you can probably get it cheaper than that!
Do it once...do it right. Even if it takes longer. | | |
