1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#459505 10/08/2008 6:16 AM
AChipmunk told me I should leave a message here. who sells kits for power steering for a 52 Chevy? I am using a 235ci and I am wondering does the pump add any noticeable strain on the motor? what will I need for the swap? Is the bracket for a 235 available or do I have to make my own?
~Jim
You won't find any new brackets for a 235, you will either have to build your own or find one. The other challenge you will have is getting a 2 groove crank pulley, the new ones are expensive. Give me your email address as I think the one I have on my truck will be available very soon.
Phil
Tudorman #459599 10/08/2008 5:11 PM
see rusty52: plenty of help on the bolt and I'm sure more will chime in:) Bolters are great!
Achipmunk #459610 10/08/2008 6:05 PM
Ex Hall Monitor
Ex Hall Monitor
Power steering??? I don't need no farging power steering! I've got power steering by armstrong. grin eeeek
Tiny #459772 10/09/2008 4:27 AM
I had the armstrong steering on my 1 ton, and had no problems. Then in the process of a disc brake install I ended up with power steering too... And it's great, you don't know how nice it is till you have it. The truck was not that hard to steer before, but now with the truck sitting still I can put one finger on the rim of the wheel and turn lock to lock, no comparison.
If you are creative you can drive the PS pump off a second belt grove on the generator pulley:
http://rides.webshots.com/photo/1484182686080251109emAXqy
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #459794 10/09/2008 5:53 AM
I guess i should have explained I Have a disability that cause my muscles to be somewhat weak. I would just feel safer having power steering. Not just for me but other drivers too. I was lucky when i got my pick-up someone in the past put a brake booster on it. if anybody can tell me what PS pump to use and the dimensions of the other parts required to make it work i could make them myself
A Saginaw P series pump is the best choice.
found on most all GM and IH trucks and cars from 60's to late 70's, and same thing but metric hardware starting early 80's. (all dates approximate)
The one in my picture linked above is one, with a reservoir for a remote can, most have an oblong reservoir folks call them a "canned ham pump"
Grigg
---All pictures---
Grigg #460439 10/11/2008 12:16 PM
Hi! All
I purchased my P/Steering & P/Front Disc kits from www.performanceonline.com call & ask for Arron he was alot of help to me with my 57 3200, I wanted to keep my stock I beam axle & 6 lug wheels
Later Phil
Chevy3200 #460643 10/12/2008 1:39 AM
i had power steering for 20 years without a two groove pulley and a mount is availble from patricks. a pulley is avaiable from bufflo interprises. and other kits are available from brothers trucks.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #460690 10/12/2008 4:28 AM
thanks you guys
