2 members (2-Ton, farmallb),
67
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | AChipmunk told me I should leave a message here. who sells kits for power steering for a 52 Chevy? I am using a 235ci and I am wondering does the pump add any noticeable strain on the motor? what will I need for the swap? Is the bracket for a 235 available or do I have to make my own? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Sep 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 46 | You won't find any new brackets for a 235, you will either have to build your own or find one. The other challenge you will have is getting a 2 groove crank pulley, the new ones are expensive. Give me your email address as I think the one I have on my truck will be available very soon. Phil | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | see rusty52: plenty of help on the bolt and I'm sure more will chime in:) Bolters are great! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Power steering??? I don't need no farging power steering! I've got power steering by armstrong.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had the armstrong steering on my 1 ton, and had no problems. Then in the process of a disc brake install I ended up with power steering too... And it's great, you don't know how nice it is till you have it. The truck was not that hard to steer before, but now with the truck sitting still I can put one finger on the rim of the wheel and turn lock to lock, no comparison. If you are creative you can drive the PS pump off a second belt grove on the generator pulley: http://rides.webshots.com/photo/1484182686080251109emAXqyGrigg | | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | I guess i should have explained I Have a disability that cause my muscles to be somewhat weak. I would just feel safer having power steering. Not just for me but other drivers too. I was lucky when i got my pick-up someone in the past put a brake booster on it. if anybody can tell me what PS pump to use and the dimensions of the other parts required to make it work i could make them myself | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A Saginaw P series pump is the best choice. found on most all GM and IH trucks and cars from 60's to late 70's, and same thing but metric hardware starting early 80's. (all dates approximate)
The one in my picture linked above is one, with a reservoir for a remote can, most have an oblong reservoir folks call them a "canned ham pump"
Grigg | | | | | Joined: Oct 2008 Posts: 10 New Guy | | New Guy Joined: Oct 2008 Posts: 10 | Hi! All I purchased my P/Steering & P/Front Disc kits from www.performanceonline.com call & ask for Arron he was alot of help to me with my 57 3200, I wanted to keep my stock I beam axle & 6 lug wheels Later Phil | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i had power steering for 20 years without a two groove pulley and a mount is availble from patricks. a pulley is avaiable from bufflo interprises. and other kits are available from brothers trucks.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | | | |
