| | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | With todays financial crisis, my budget for the truck has been virtually eliminated so I've been looking for some creative ways to save some money. With that in mind I came up with a low budget, low tech fan shroud. This is what I came up with. It's two 17x11 baking sheets I got from Walmart for $10. I cut off one side of each one, traced and cut out the hole for the electric fan and bolted the halves together. I then bolted the fan over the hole and used plastic ties to secure it to the radiator. It works good considering what it's are made of and there's plenty of clearance. I know I'll more than likely replace the radiator & get another shroud eventually, but for now I'll use this setup! Stop laughing!!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Hey - no laughing here. Plato once said that necessity is the mother of invention. Good job.  | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | 54TOW.....I'll second that!  And any dead bugs that get through won't stick!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Now only if he sprays it with PAM!! Ha. Ha. On the serious side that is using the brain for something other than dreaming. Good Job. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Great ingenuity, looks good also, great work!!! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | YUP...that is one cool pc. of engineering..and might I say THRIFTY!!!!...good for you ! Tim | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Looks good to me man. You need to Patent that "The mobileortho Non-Stick Fan Shroud" maybe you can sell the concept to Ronco.
I salvaged the two fans off the firebird that I got my TPI out of, How big is that fan? Is it aftermarket or one that was on the car you got the engine from?
Steve | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | Cool!!  | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Looks good to me man. You need to Patent that "The mobileortho Non-Stick Fan Shroud" maybe you can sell the concept to Ronco. Hey, I like the sound of that!! The fan is actually one that was on the radiator when I got the truck. Looks like the PO was using it as a backup to the stock fan.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Looks good... now you're cookin'!  ~Trev | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | GREAT IDEA !! I like it !  Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm not laughing, I used a heavy duty cake pan to make the transmission "hump" in one of my 48 1.5 tons. No one is the wiser unless I point it out to them, Scott | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Now for the burning question- - - - - -how does it work under max-load conditions? I'd be very reluctant to put much of a heat load on that radiator with that much of the core blocked off to the passage of ram air at highway speed. It might work OK for idling around town in a traffic jam, but something tells me when there's a heavy load in the bed and you're on a steep hill at cruise speed, the temp is going to skyrocket. Jerry
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Now for the burning question- - - - - -how does it work under max-load conditions? I'd be very reluctant to put much of a heat load on that radiator with that much of the core blocked off to the passage of ram air at highway speed. It might work OK for idling around town in a traffic jam, but something tells me when there's a heavy load in the bed and you're on a steep hill at cruise speed, the temp is going to skyrocket. Jerry Watch your temp gauge and carry some tools with you. If it gets too hot pull it off and go to plan "B".
~Jim
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | but something tells me when there's a heavy load in the bed and you're on a steep hill at cruise speed, the temp is going to skyrocket. Jerry Not really planning on hauling anything but far as the overall design goes, I patterned it after something like this. I figured that if they could market it and sell it for $185, surely my $10 version should work as well.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I used a 100qt pot and a Mirro Snow coaster once to make an aluminum fan shroud. 'Roders use what they have on had.
| | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | I don't want to burst any bubbles, but don't some of those cookie sheets rust? I know I have some that has if I didn't wipe them down well. I do love the thought, and always love the idea of using whats on hand! Great work! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | A suggestion re. rust. Check with the scrap metal yards or used restaurant equipment suppliers or restaurant equipment auctions for stainless steel. It sells by the pound and while not too cheap something that size could not be much.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I used a 100qt pot and a Mirro Snow coaster once to make an aluminum fan shroud. 'Roders use what they have on had. I agree Scott....Is that not the whole 'ethos' of Rodding?  It's all too easy to break out the cheque book nowadays. Back in the 40's and 50's the guys used what they had available. Sure it's nice that there are suppliers to "cater" for our needs. (pun intended!)  I myself have scoured the junkyards for alternative answers to things like the windshield wipers for my A.D. I'm using a series one Land Rover set-up with slight modification. Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | "It's all too easy to break out the cheque book nowadays. Back in the 40's and 50's the guys used what they had available." Most stuff back then, today we call "rat rods". No one could afford a 15000.00 paint job or a body man at $____ an hour and if you didn't have the skills necessary you "made do". But today we whine if we must pay $3 a gal. to put gas in our cushy cars. 29 cents a gallon sounds like heaven today but entertainment was so limited cruising between teenage hangouts was about all we had.
~Jim
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | No one could afford a 15000.00 paint job or a body man at $____ an hour and if you didn't have the skills necessary you "made do". I still can't!! I want to make sure I have a dependable cruiser or "ratrod". Most of my parts were gathered from the junk yards or ebay, or I just made them up as I went along with my limited skills. I try to make due with what I have lying around. Heck, I don't evn have a garage!! I'm thinking very seriously on just a black satin paint job when I'm all done that I may even try to do myself.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That's the best way to go. When you're finished you will have much more pride in the product if you did it yourself.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I'm thinking very seriously on just a black satin paint job when I'm all done that I may even try to do myself. And that is what I am talking about. Mobile, I myself am looking to go the flat black route....with red wheels Scott
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Satin Black and red steelies it's hard to beat!! Just remember to use a flat/satin top coat, primer is porous and lets the moisture in!! Good luck! Jock 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Just remember to use a flat/satin top coat, primer is porous and lets the moisture in!! Good luck! Jock Back in the day, when we would do piecemeal body work under a tree outside the house, on Saturdays, we would prime between steps. I remember if you left it on here too long it would disappear. I don't think we had that product back then.
~Jim
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Just remember to use a flat/satin top coat, primer is porous and lets the moisture in!! Good luck! Jock What about a coat of clear on thop of the primer?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | A satin clear coat would work, as long as it seals the primer I don't see that it would be a problem. Good point!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
