1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Having problems with brakes, Have new dual master cyl, today a new vacuum booster. Running drum brakes on all 4 ( going to change) The Brake pedal works fin on 25% braking, when you slam it to the floor, you get good brakes but not great. Can't lock them up. It just feels like you reach the bottom of the stroke and no more. Talked to a speedway rep this week at the street rod ants and He thought the master cyl might be at fault (I bought it from them) Ideas?? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Still has air in the system??? Kinda sounds like it.
Jeff | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Have you adjusted the brakes? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I agree with Cletis, When I first reassembled my truck Mine were like that until I adjusted up my rear drum brakes again, I think my pads centered themselves up when I got on the road for the first time and were not adjusted properly, after a readjustemnt I got a full pedal and can now lock up the tires if I need to. Tim | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Did you bench bleed the master cylinder prior to installing on the truck? I have seen many units have air in them.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Blah blah blahhhhbla brakes, Blah blah blahhhhbla new dual Blah blah blahhhhbla , today a new Blah blah blahhhhbla . Blah blah blahhhhbla you get good brakes but not great. Blah blah blahhhhbla Brakes? You don't need no stinkin' brakes.  | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Bled the brakes and master cyl. before instillation adjusted brakes twice. Air would cause a spongy pedal. Mine is like a rock.
Just my wishful thinking Lonnie, I pretend my truck is fast. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | might be in your wheels :  D install your old ones back and you will be good to go you might check with Trev, he just finished plumbing his 37 click here
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | It sounds like you have front brakes only. I would bleed the rear brakes again, then the master cylinder at the rear fitting.
Sometimes there can be air trapped in the master cylinder and it won't work itself all the way into the brake lines.
I only say this because it has happened to me. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Will try again on the master cyl. All 4 brakes are working. can see skid marks on gravel and the drums are all warm equally. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Joker, You might have a issue. The 20 inch wheels are a lot harder to stop than the 16 inch? | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The overall height of the tire/wheel assembly will be a factor. If a 15" wheel and a 20" wheel have tires that are about the same height by comparison, the stopping ability will be similar. Most of the 20's I've seen have about an inch and a half of rubber on them. If the 20's are taller overall, there's more leverage on the brakes, and less stopping effect.
Maybe the truck is embarassed to have those ugly wheels on it, and it's trying to run away from them! Jerry
| | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | I agree with Hotrod lincoln the reason it won't stop is because it is looking for a big pothole to hit so it will bend the rims on those 20's LOl. I am just kidding no hard feelings I hope!! I hate to explain this but on my 1937 Plymouth I had the same problem until I re-bled the master cylinder some vehicles are very touchy that way | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Ok you guys have been getting coaching from the Joker on the ugly wheels. I hope you know that anybody under 40 thinks they are HOT. Too bad I am over 40 but I paid for them, now I have to stick up for them or die of embarrassment.
Now fix my brakes.
| | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | Hey I am under 40 and I don't like them. But that is me. all that matters is if you like them. quick question do you have a proportioning value for the rear brakes? on other cars and trucks that I have done if you don't have that adjusted properly it can cause all sorts of problems. locking up to soon or not locking up at all. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Some of the brake shoes we get now just don't have a lot of friction in them. They have taken out the asbestes. Ive had to throw away perfectly good shoes that came with trucks when I bought them. Ive been useing Carquest brakes & a guy drove my 58 a while back & remarked how good it stopped. He said it felt like it had power brakes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | As Wrenchbender mentioned, Ive spoken with a local guy who has been friends with my family for the past twenty or so years. Hes owned his shop for a lot longer. He commented on how many people bring in their vehicles because theyre squealing or just dont feel right, although theres nothing wrong with them. He started seeing it more and more once they switched from using asbestos in the pads and shoes.
gazim, what wheels do you have that these clowns you a hard time for? Got a picture handy?
Jeff | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm over 40 and have 20's on three of my trucks. My '47 COE, my '51 4400 and my '52 6400. 7.50-20's...
Wheel and tire choice can affect your brakes. While we've talked about height, width can have an impact too. If the weight of the wheel/tire combination have increased that will reduce your braking effectivness.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Played with it all day, rebled the master, and finally got around to changing the lines into the master, Helped, is there a difference between the forward outlet on the master to the rear.?? I don't believe I need a proportioning when running drum brakes on all 4. (Going to change)
| | | | | Joined: Aug 2008 Posts: 18 New Guy | | New Guy Joined: Aug 2008 Posts: 18 | I'm not sure if this will help or not but here goes.I'm about a week ahead of you in your problem.I had very little pedel if any and I guess I bleed about 3 qts of fluid until early one morning it finally hit me,the wheel cylinders are doing there job,its just that the shoes are not reaching the drums simply because I had not adjusted them PROPERLY.So I removed the wheels,then the drums and found out only one half of the shoe was touching(bairly) one the front left and oposite shoe was touching on the other side.The wheel cylinders exert equal pressure on the shoes so BOTH shoes need to be adjusted equally.I have a 46 1.5 ton and I'm glad this portion is done. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Gazim...I was led to believe that the front and rear outlets on your master are different. Think about it... The front brakes need to actuate first (they do something like 80% of the work)
Is it possible you have/had them mixed up? Remember if it's the under floor set-up the m/c will be back to front,relative to a conventional firewall m/c.
Have you checked the pushrod free play? I would say adjust the pushrod 'till you get about 1/2" play at the brake pedal.
Maybe worth checking, I hope this helps. Jock. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Bota brought up a good point. Sometimes guys are afraid to adjust them up. Tighten them till you get a heavy drag & back it off about 4 notches. you still will have some drag but as they seat in it will be OK. These drums are seldom true. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
