2 members (Ponchogl, Shardean), 85 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#452074 09/13/2008 8:51 PM
Having problems with brakes, Have new dual master cyl, today a new vacuum booster. Running drum brakes on all 4 ( going to change) The Brake pedal works fin on 25% braking, when you slam it to the floor, you get good brakes but not great. Can't lock them up. It just feels like you reach the bottom of the stroke and no more. Talked to a speedway rep this week at the street rod ants and He thought the master cyl might be at fault (I bought it from them) Ideas??
gazim #452125 09/13/2008 11:56 PM
Still has air in the system??? Kinda sounds like it.
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #452160 09/14/2008 1:31 AM
Have you adjusted the brakes?
Cletis #452253 09/14/2008 6:13 AM
I agree with Cletis,
When I first reassembled my truck Mine were like that until I adjusted up my rear drum brakes again, I think my pads centered themselves up when I got on the road for the first time and were not adjusted properly, after a readjustemnt I got a full pedal and can now lock up the tires if I need to.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #452307 09/14/2008 1:36 PM
ODSS Lawman
ODSS Lawman
Did you bench bleed the master cylinder prior to installing on the truck? I have seen many units have air in them.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
gazim #452482 09/15/2008 1:08 AM
Originally Posted by gazim
Blah blah blahhhhbla brakes, Blah blah blahhhhbla new dual Blah blah blahhhhbla , today a new Blah blah blahhhhbla . Blah blah blahhhhbla you get good brakes but not great. Blah blah blahhhhbla
Brakes? You don't need no stinkin' brakes.
grin
Avette4me #452608 09/15/2008 2:06 PM
Bled the brakes and master cyl. before instillation
adjusted brakes twice. Air would cause a spongy pedal. Mine is like a rock.
Just my wishful thinking Lonnie, I pretend my truck is fast.
gazim #452614 09/15/2008 2:20 PM
might be in your wheels : grin D
install your old ones back and you will be good to go
you might check with Trev, he just finished plumbing his 37
click here
Redryder pix
My Hotrod
joker #452625 09/15/2008 2:43 PM
It sounds like you have front brakes only. I would bleed the rear brakes again, then the master cylinder at the rear fitting.
Sometimes there can be air trapped in the master cylinder and it won't work itself all the way into the brake lines.
I only say this because it has happened to me.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #452923 09/16/2008 2:16 PM
Will try again on the master cyl. All 4 brakes are working. can see skid marks on gravel and the drums are all warm equally.
gazim #453376 09/17/2008 10:21 PM
Joker, You might have a issue. The 20 inch wheels are a lot harder to stop than the 16 inch?
gazim #453381 09/17/2008 10:39 PM
The overall height of the tire/wheel assembly will be a factor. If a 15" wheel and a 20" wheel have tires that are about the same height by comparison, the stopping ability will be similar. Most of the 20's I've seen have about an inch and a half of rubber on them. If the 20's are taller overall, there's more leverage on the brakes, and less stopping effect.
Maybe the truck is embarassed to have those ugly wheels on it, and it's trying to run away from them!
Hotrod Lincoln #453392 09/17/2008 11:03 PM
I agree with Hotrod lincoln the reason it won't stop is because it is looking for a big pothole to hit so it will bend the rims on those 20's LOl. I am just kidding no hard feelings I hope!! I hate to explain this but on my 1937 Plymouth I had the same problem until I re-bled the master cylinder some vehicles are very touchy that way
rusty52stovey #453746 09/18/2008 8:11 PM
Ok you guys have been getting coaching from the Joker on the ugly wheels. I hope you know that anybody under 40 thinks they are HOT. Too bad I am over 40 but I paid for them, now I have to stick up for them or die of embarrassment.
Now fix my brakes.
gazim #453757 09/18/2008 9:02 PM
Hey I am under 40 and I don't like them. But that is me. all that matters is if you like them. quick question do you have a proportioning value for the rear brakes? on other cars and trucks that I have done if you don't have that adjusted properly it can cause all sorts of problems. locking up to soon or not locking up at all.
rusty52stovey #453769 09/18/2008 9:42 PM
Riding in the Passing Lane
Some of the brake shoes we get now just don't have a lot of friction in them. They have taken out the asbestes. Ive had to throw away perfectly good shoes that came with trucks when I bought them. Ive been useing Carquest brakes & a guy drove my 58 a while back & remarked how good it stopped. He said it felt like it had power brakes.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #453784 09/18/2008 10:30 PM
As Wrenchbender mentioned, Ive spoken with a local guy who has been friends with my family for the past twenty or so years. Hes owned his shop for a lot longer. He commented on how many people bring in their vehicles because theyre squealing or just dont feel right, although theres nothing wrong with them. He started seeing it more and more once they switched from using asbestos in the pads and shoes.
gazim, what wheels do you have that these clowns you a hard time for? Got a picture handy?
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #453901 09/19/2008 2:22 AM
I'm over 40 and have 20's on three of my trucks. My '47 COE, my '51 4400 and my '52 6400. 7.50-20's...
Wheel and tire choice can affect your brakes. While we've talked about height, width can have an impact too. If the weight of the wheel/tire combination have increased that will reduce your braking effectivness.
OldSub #454215 09/19/2008 10:43 PM
Played with it all day, rebled the master, and finally got around to changing the lines into the master, Helped, is there a difference between the forward outlet on the master to the rear.?? I don't believe I need a proportioning when running drum brakes on all 4. (Going to change)
gazim #454464 09/21/2008 2:31 AM
I'm not sure if this will help or not but here goes.I'm about a week ahead of you in your problem.I had very little pedel if any and I guess I bleed about 3 qts of fluid until early one morning it finally hit me,the wheel cylinders are doing there job,its just that the shoes are not reaching the drums simply because I had not adjusted them PROPERLY.So I removed the wheels,then the drums and found out only one half of the shoe was touching(bairly) one the front left and oposite shoe was touching on the other side.The wheel cylinders exert equal pressure on the shoes so BOTH shoes need to be adjusted equally.I have a 46 1.5 ton and I'm glad this portion is done.
bota #454468 09/21/2008 2:52 AM
Gazim...I was led to believe that the front and rear outlets on your master are different.
Think about it... The front brakes need to actuate first (they do something like 80% of the work)
Is it possible you have/had them mixed up?
Remember if it's the under floor set-up the m/c will be back to front,relative to a conventional firewall m/c.
Have you checked the pushrod free play? I would say adjust the pushrod 'till you get about 1/2" play at the brake pedal.
Maybe worth checking, I hope this helps.
Jock.
More pix on Flickr.
jockbolter50 #454548 09/21/2008 3:08 PM
Bota brought up a good point. Sometimes guys are afraid to adjust them up. Tighten them till you get a heavy drag & back it off about 4 notches. you still will have some drag but as they seat in it will be OK. These drums are seldom true.
