5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#449810 09/07/2008 2:39 AM
i took a test drive on my 53 3/4 on truck, took it out for the first time on friday. It didnt want to go in 3rd. sound like it was grinding gears.wouldnt got in 4th either. it changes gears well sitting still. the clutch releases about 2 inches from the floor before the clutch engages. im 53 and have no memory of changing gears with no syncsinizer. the shifter is in the floor. am i doing somehting wrong, or any sugesstions.
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
Your clutch pedal should have maybe 3/4" play at the top and be disengaged long before 2" off the floor. How is your free play at the top?
1951 1 Ton Completed
you mean when i push the clutch in it should start to engage 3/4 inches from the top?
Yes.
My 1953 Chevrolet
1947.1 Gallery
It should start to disengage! smile
Stuart
Yes, disengage.
