| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i took a test drive on my 53 3/4 on truck, took it out for the first time on friday. It didnt want to go in 3rd. sound like it was grinding gears.wouldnt got in 4th either. it changes gears well sitting still. the clutch releases about 2 inches from the floor before the clutch engages. im 53 and have no memory of changing gears with no syncsinizer. the shifter is in the floor. am i doing somehting wrong, or any sugesstions. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your clutch pedal should have maybe 3/4" play at the top and be disengaged long before 2" off the floor. How is your free play at the top? | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | you mean when i push the clutch in it should start to engage 3/4 inches from the top? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | It should start to disengage! Stuart | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | | | |
