| | | Forums66 Topics128,043 Posts1,055,615 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | can anyone share the information on the canister oil filter,how to clean it and what material to use.Is there a modern oil filter adapter that i could use that would not cost a arm and leg.thanks no more than i will be driving it, would you suggest keeping the old one. | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | thanks, someone told me toilet paper was the filter. i like this website. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | They would have came with two sizes (or none) in '53 from the factory. Measure the size of the cannister to determine if you need the tall filter (somewhere around 8" tall) or the small filter (around 4-5").
These old filters can be picked up off the shelf at Napa for $8-10. Ill look around and see if I can come up with the part number. You may also be able to take the old filter out of the cannister and look for a number on the side of the filter.
Jeff | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Or, if you know if it's a FRAM or an AC brand (Fram has dimpled bottom, AC smooth cone shaped bottom) and you have the year of your truck (1953), your local auto parts store should have them in stock. They may also want to know the engine size (216, 235, etc.) Like rustednuts said, about $10. I have restored over 30 of these canisters, if you have any questions on paint, oil line fittings or decals, don't hesitate to give out a shout. Wada | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | need to know all of that, i just found out today its a 235. i had to take it off tempoarly because of the hose leaking, any info would be great. | | |
