2 members (Jims46, klhansen),
125
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,995 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Can anyone tell me if this is 216 or 235? Ebay motor I've been looking for 235 to get rebuilt while I'm waiting for my 216 to give out. It seems like I have seen post along this line in the past, but I have had no luck with the search feature. Of course, my best bet would probably be to request the engine numbers from the seller.
53 Dumpy
1951 Chevy 3100 "Ernestine" 1970 Chevrolet C10 "Ol' Blue" 1940 JD "long-hood" B 1959 Jeep FC-170 1960 IH B275 2013 Chevy Silverado 2023 GMC Denali 2500HD
| | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | It's most likely a 54-up 235, as there's a valve cover on it that attaches with 4 small bolts on the sides of the cover, and it appears the side cover does not extend above the block. The 216's and splash-oiler 235's has a side cover that went to the top of the cylinder head. Jerry
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | the engine number might work best.. should not be hard for him to do that being the engine is out..like about a couple of min.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The 216's and splash-oiler 235's has a side cover that went to the top of the cylinder head. Not quite true. tclederman pointed out to me awhile back that the later babbited 235s, 1950-1953, had the short side cover. Jeff | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Get the block and head number. If it is a 1954 it will drop in without water pump modifications if it is after 55 you will have a clearance issue. You will probably need to do some changes in regards to rear bellhousing and mounts as well. Its important that it turns free if not removing the bellhousing becomes a bit more problematic. I looked close at the pictures and it looks like a 235 to me you just need to check the numbers, it is not unusual to see 261 heads on some of these engines due to cracking issues with 216 and 235 originals.
CHEVROLET CASTING NUMBERS FOR IDENTIFYING THE YEAR AND APPLICATION, CYLINDER HEADS AND BLOCKS
CYLINDER HEADS
1941-48 839401 All 216 and 235
1949 3835409 All 216 and 235
1950-53 3835517 All 216
1950-52 3835499 216
1950-52 3835909 235
1953 3701887 235
1954-55 3835913 235
1954 3635499 261 Truck
1955 3708570 216 Truck
1956 3836848 235
1953 Corvette 6 Cylinder
1954-55 3836241 Corvette 6 Cylinder
1955 3703523 Passenger, Corvette V-8 265
1956 3725306
1956 3837064 Passenger, Corvette, V-8 265
1957 3731554 Passenger, Truck V-8 283
1957 3731539 Pas w/4BC V-8 283
1947 3740997
CYLINDER BLOCKS
1941 839400 216 Passenger & Truck
1942-47 839770
1942-47 839910 216 Passenger, Truck
1942-47 3835335
1942-47 839751 235 Truck
1948-49 3835497 216 Passenger, Truck
1048-49 3835309 235 Truck
1950-51 3692703 235 Passenger Powerglide
1950-51 3835497 216 Passenger, Truck
1950-51 3692713 235 Truck
1952 3835692 235 Passenger with Powerglide, Truck
1952-53 3835849 216 Passenger, Truck
1953 3701946 235 Except Powerglide
1953 3701481 235 Powerglide
1954 3701481
1954 3835911 235 Powerglide
1954 3701481 235 Excluding Powerglide
1954-55 3702436
1954-55 3703414 261 Truck
1955 3835911
1955 3733949 235 Excluding Powerglide
1955 3836233 235 with Powerglide
1955-56 3836340 261 Truck
1953-55 3835911 235 Corvette 6-cylinder
1955 3703524 265 V-8 Passenger, Corvette
1956 3720991 265 V-8 Corvette
1957 3731548 283 V-8 with 2 BBL carburettor
1957 3867802 283 V-8 Fuel Injection
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 53 Dumpy,
Try to get the block and head casting numbers from the seller. Post them here and someone should be able to identify what it is.
As stated above, it could be a 1954-1962 235. Or, it could also be a 1954-1963 261.
Tim | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | I'd like to know to. How about the emerg brake? Is that a true stop from a school bus? | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | If it is anywhere close to you, you can't go wrong. There is no bids, no indication of a reserve. It has an alternator as well. Gotta be a good buy for scrap if nothing else. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 46Canopy,
The engine/transmission shown is from a 2 ton truck. Most rigs 1 1/2 ton and up used this style parking brake. It's very common...nothing special, just not for pickups.
Stuart | | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | Wouldn't the engine be usable if it is the 235?
I drug home a 47 3600 that someone installed this set up in. Let's just say it's in there..... but shouldn't be done.
Jim | | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Block number is 3837004 Head number is 3836848
What am I looking at?
53 Dumpy
| | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | I may have the answer to my own question. It looks like from inliners.org that it is a 55-57 235 CI. Will I be able to swap out my 216 mounts, bellhousing and tranny to put it in my '51 3100? Is the water pump shaft length the only issue in putting the newer engines in place of the older? Can I replace the water pump and be ready to go?
53 Dumpy
| | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Well, she's all mine. $103 for complete engine and tranny. Now I've got to get it home and talk to the engine shop.
53 Dumpy
| | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Ok, I've got it back home and the stamped number on the boss behind the distributor is F315A. What does this tell me?
53 Dumpy
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | That style of engine ID started being used in 1957: F315A F = built in Flint, MI 3 = March 15 = 15th day of that month A = 235 engine in a car with a standard/manual transmission This information does not help with the year. Maybe you can find the block and head date casting codes and post them here? All 1957 and later automobile 235 engines came with hydraulic lifters. | | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | The block and head numbers are listed in an earlier post and Inliner's website indicates that the engine is a 55-57 235. If the style of engine ID started in 1957, then it would seem that I have a 1957 235 that was once in a car, but at some point was put into a big truck with a 4-speed and a driveshaft e-brake (since that's what is hanging off the back of it now). A 235 with hyd lifters would be a nice replacement for my 216.
I think since it is still on the trailer, I will run it down to the engine shop and have them dig into it and tell me if it is a good candidate for (A) a rebuild or (B) a source of parts. I'm hoping for (A).
53 Dumpy
