Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (tclederman, Woogeroo, rfs56trk), 49 guests, and 5 robots.
Topics128,010
Posts1,055,303
Members48,419
#43931 06/15/2004 9:25 PM
For years the Speedometer and Odometer on my '63 c-20 did not work. I replaced the cable, and now the speedometer works but not the odometer. Does anyone know of a place to get a rebuilt or new speedometer/ odometer assembly? Or how to fix this one? I can't see anything wrong, but then again I'm not sure what I am looking at.
Glen E.
#43932 06/15/2004 9:47 PM
Junior Member
Junior Member
Here's a link to a speedo shop in Cal. They can
probably fix it or upgrade it.http://www.speedometershop.com/40year.htm
#43933 06/15/2004 11:39 PM
Check out my link in the Electrical Bay. The shop's closer to you.
#43934 06/16/2004 3:27 PM
If you have a spare odometer, take it apart to see how it works. Very interesting mechanically!
My original odometer worked but all (and I mean all) the paint and numbers had fallen off. The replacement decals say to align the zero's of the new number strips with the original zero's. I couldn't do that so I just stuck on the new decals. That does not work! When the tenth's digit got to 6, the next wheel turned. When that one got to 3, the next one turned. I bought another one off E-bay.
#43935 06/16/2004 5:40 PM
The speedo input basically turns a magnet that exerts a drag on a disk. This is what the speedo needle is attached to. The speedo input also drives the odometer thru a few gears. It is likely one of these gears that is stripped out. All you need is a spare unit with good gears and you should be able to fix the one you have.
#43936 06/16/2004 8:16 PM
Usually if the odometer doesn't work it's a small gear that needs replaced. If you need someone to rebuild or need parts, contact Jeff at www.bowtiebits.com in Wichita.
Fred
52 3600
69 C-10
