| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Hi Folks, got home from a cruise today and when I went to roll the key back to shut off the truck NO GO!it will NOT turn back, ended up having to pull the coil wire to kill the motor, I disconnected the battery and now here I sit, Steering column is out of a mid 70's chevy car, tilt wheel. I have had issues in the past week having to "jiggle" the connecting rod that runs down the column to the "starter" switch I pressume?, seems NOW it just plain came apart or is somehow jammed into position, Im going to start digging into the inards of the column to get to the key switch barrell, ANY input on what I should be looking for??? Thanks, Tim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The switch mounts on the side of the column between the dash & floor. That is usually the problem. 2 screws hold it on. Pull the switch loose & see if the key will turn. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | I've seen this one time before. One of the tumblers in the ignition switch broke and jammed the key. It wouldn't turn and the key would not come out. Replaced the ignition key set and worked fine.
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | The exact thing happened to me last night. I've been wiring mine up and last night the darned thing would not turn back and its a fairly new switch. I was going to remove it from the column anyway and use the dash switch so it just forced me to deal with it sooner than later..
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Had the same thing on a F#$% truck. Replaced the ignition setup and everything was OK.
~Jim
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | well after removing the lock assy I was able to start the truck for a few days with a pair of pliers while searching for a new lock set, then I found the culprit the inner mechanism in the tilt wheel, the gears that engages the the rod that runs down the column to the switch went south and broke into a few pcs. Binding up is what most likely killed the lock set then the rest went afterwards. So I am patiently waiting for the IDIDIT column I just ordered. Tim | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | My buddy just had his tilt Olds key that he couldn't get out of the lock when shutting off. He took it to a dealership and they put in a new ingnition switch in the column. Does the same thing after the bill and he gets it back. In that column there is a collar that turns with the floor shift so you can't turn the key unless it is in park or neutral. The timing of that collar was off.
Before correcting the problem, I could get the key out by moving the tilt up and down at the same time as turning the key to the off position. | | |
