0 members (), 40 guests, and 10 robots.
Topics128,012
Posts1,055,315
Members48,419
#42759 09/10/2004 2:45 AM
Hi Bolties! I drove my 49 tonight, and it started to mis once in a while, going down the road. Kinda like it was sputtering out.Then on the way home, it missed continously on acceleration. It even back fired once or twice when I was giving it the gas. Wasn't sure I was going to get it home. It don't seem to mis at idle. I think it is most likely a fuel problem, maybe the accelerator pump. The carberator isn't in too bad a shape, and the engine is fresh from the rebuild shop. Any thoughts? frown
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#42760 09/10/2004 2:58 AM
Check the charging system. low or no charging voltage will make it miss and backfire as the battery voltage gets low.
#42761 09/10/2004 3:27 AM
Thanks Jerry (HRL). I will check that. I don't think the batt is low, the volt meter gage seemed to be on the positive side, but I will check it and make sure. smile
KT
49 Chevy 3/4 ton
#42762 09/10/2004 3:47 AM
Sounds like fuel starvation. A plugged filter or line or a weak fuel pump may be the cause. Start with the cheapest, the fuel filter then go from there. I usually put a clear filter on any vehicle that hasn't been driven much just to see what gets sucked from the tank and into the fuel system. Today's fuel will slowly clean your tank and send the crud down your fuel lines.
Just my 2 cent worth,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#42763 09/10/2004 11:44 AM
2 Offline
Sticking valve or lifter?
#42764 09/10/2004 1:32 PM
I had the same exact problem and it turned out to be the coil.
Not quite as lean
Not quite as mean, but
Still a Marine!
#42765 09/11/2004 1:10 AM
Ditto with the coil. I actually had a new coil on mine, but my alternator was overcharging the battery. So, the coil got friend. Just my 2 cents. John
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI
1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
#42766 09/11/2004 4:13 AM
Thanks guys. Well, the tank has just been cleaned and sealed, so I don't think it would be the tank. It has a brand new fuel pump on it and it is working well, you can see the fuel moving in the glass bowl when it is running. I just put a new fuel filter on it about 3 weeks ago, but that was B4 I cleaned & sealed the tank. I guess it's possible it could be plugged. I actually did wonder about the coil though, because when we first got the new engine running, we had a similar problem at that time and we changed out the old coil (I didn't put a new on it at first like I should have) and it ran great. It has a new coil on it, but I did wonder if by chance it could have went bad. I don't know. I thought tomorrow I would check the points gap, and some other things & go from there.
Thanks!
KT
1949 3/4 ton Chevy
#42767 09/13/2004 8:23 AM
I'm leaning toward the fuel filter. It sounds identical to the problems I was having. Actually I still am because I haven't gotten my new tank yet, but the crud was plugging up the fuel filter and the symptoms were exactly what you are describing.
Dave
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
#42768 09/13/2004 7:55 PM
I'm not familiar with the '49 3/4 ton, but my '53 3100 has a vacuum advance on the distributor.
You originally mentioned that it sputtered on acceleration but not so much at an idle. Could it be that the vacuum advance isn't working properly?
#42769 09/14/2004 2:05 AM
Ok Bolties, the saga goes on! Tonight I did some more checking on the ignition system and here's what I found. With the dist. cap off, a friend cranked the engine over, and there is fire at the points. We then put the cap back on, and removed the number 1 plug, left the wire on it, and cranked the engine. There was no fire at the plug, and the plug was pretty black with carbon when we pulled it out. That is telling me a couple of things. First, either the cap is bad, and or the plug wires including the coil wire to the cap is bad, and second the spark isn't hot enough, which could be a result of faulty wires,
or bad coil. Even though it is new. I am going to get a new cap, wires, and coil tomorrow and see if that will fix it. Time will tell. Thanks to all who gave tips and advice! smile I will report back after replacing these items and let you know the outcome.
Thanks!
KT
49 3/4 ton-5 window Chevy Truck
#42770 09/15/2004 3:37 AM
Ok, tonight I put on a new coil, and a new dist.cap. I also changed out the points. They are getting fire. I checked (with a test light) & key on and there is fire to the coil and out of the coil to the dist. but, still no fire to the plugs. I have to say that I'm stumped. I can usually figure these things out, but this one is a real deal. Anymore thoughts?
Thanks!
KT
49 3/4 ton Chevy
#42771 09/15/2004 2:43 PM
You didn't mention but assume you checked to make sure rotor is contacting both the terminals on inside of distributor cap. one from coil and then the outgoing to spark plug wires. If you have a little debris the cap won't catch the little notch on distributor and seat properly and that would cause lack of fire to the wires
#42772 09/16/2004 1:35 AM
Hi kb3csw! I put a new cap on lastnight, along with a new coil. I'm pretty sure the rotor is contacting the the areas. Today at work, I got to thinking about the problem. I had fire from the ignition switch to the coil, and from the coil to the dist. I never thought to check the wire from the cap to the coil. Tonight I borrowed the new wire off my wife's truck, and I now have fire to the spark plugs. But, I still can't get the truck to fire up and start. I have made sure the points are setting on .19. I have even tried another set of points, and another condensor. The battery was starting to get weak, so I hooked it up to the charger. I will just have to keep trying to get to the bottom of the problem... Thanks to all who have been so helpful! smile
KT
49 3/4 ton Chevy
#42773 09/16/2004 11:38 AM
Did you try putting a little gas down the carb, just to be sure?
#42774 09/17/2004 2:04 AM
Hello again bolters! Well, here's the latest. Today, I put a complete new set of plug wires on the truck. I bought a new condensor, and set of points. I checked and made sure the plugs had fire and they do. I pulled the new cap to coil wire out a bit and cranked the truck over just to make sure I have fire from the coil to the dist. cap and the fire was really jumping out of the coil. So, there is most definately fire there. But,,, the truck still won't start. I have to wonder now if it may be in the carb. Chuckthetruck, yes I have poured gas into the little horn of the carb trying to get it to start. I have never had such a problem that kept me stumped me like this one. I feel it must be something really simple, but it really has me puzzeled. :confused:
KT
49 3/4 ton Chevy
#42775 09/19/2004 11:16 PM
Riding in the Passing Lane
This gas we get know can carbon up the spark
plugs when you get to much of it. I believe
you mentioned the plug was dark with soot.
Try cleaning the plugs.
1972 Chevy c10 Cheyenne Super
#42776 09/20/2004 1:38 AM
Hi Wrenchbender! Yes, I did clean the plugs. Didn't change anything. I have to wonder if the problem is in the carb. There is fire every where it is supposed to be in the ignition system.
KT
49 3/4 ton Chevy
#42777 09/20/2004 10:04 AM
just a idea. Change the cabels on the distributor for 180 degrees. It happened to me several times. You put in the distributor, set the engine on first OT and the car refuses to start.
It was the wrong OT. Remember this is a 4 stroke engine so you have 2 OTs.
So for a quick check (just to make sure) reconect the wires on the dizzy for 180 degrees. So #6 is your new #1 - 5 is 2 - 3 is 4 - 1 is 6 - 2 is 5 and 4 is 3.
hope that helpes
#42778 09/24/2004 2:29 AM
Hi bolters! Well, the engine problem is over. In summary, here's what happened. The coil wire from coil to dist. cap was bad, which was the original problem. In attempting to find the problem, and replacing some ignition parts, I replaced the spark plug wires. The reason it wouldn't start, it because I had the plug wires off 1 hole. I hate to say, but that was it. The sweetest sound was when the stovebolt started & ran so smooth!
Thanks for all the great help you all offered. It's hard to diagnosis a problem when you can't see the vehicle. smile
KT
1949 3/4 ton Chevy
