8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 38 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#424147 06/17/2008 10:33 PM
See pic here Picasa
Some guys have all the talent!! Looking good Weeds. Is it to far for you come do mine? The food is good down here:)
Chip, thanks for the reply. Boiling Springs is a long way from here and I'm sure the food is excellent and the Southern hospitality is as well. Maybe we will meet up sometime as I did with Tony in Weatherford and had a ride in his Panel. When my sub is done I plan on plenty of trips and maybe SC can be one of them. The pic that I posted was an experiment to see if I could actually post a pic. A much younger person is trying to get the procedure thru my rather thick Norwegian skull.
Weeds
Hey, you never know when I may get up your way!! I have a good stovebolt friend up in Northfield that owes me a Porterhouse staak and I plan to collect one of these days. ( I was also stationYou come on down, maybe by then I'll at least have the body back on the chassis. I'm just about to get into the body work later this year and I know its not gonna be fun...even though I have most of the repair panels/patches ready.
Thanks, Weeds for all the documentation your doing.
OH....when you pulled off your original wood body blocks did you notice that the blocks of wood were held in place under the body by NAILS being driven through the wood blocks and into the metal piece that sits on the blocks?
Take care.
The nails that hold the 47-55 panel-body wood blocks to plates on the chassis are spiral wood nails. Here are a few extracts about spiral nails:
"Spiral nails have a spiral line down the shank, somewhat like the threads of a screw. These nails are used for securing hardwood flooring, attaching siding, and building rafters. They have great holding power, and are very squeak-free.
Spiral nails turn like screws and hold tighter than regular nails."
Here are galvanized spiral nails.
Here are stainless spiral nails.
McMaster-Carr also has two types of spiral nails, galvanized/stainless/etc (search on spiral nail}
Are the lower rear corner patches available after market? Nice looking work.
Robert
Robert,
Jim Carter sells the 47-55 Panel Body lower rear corner patch panels that are made by Ray Stanley of Wheelwright Restorations in MA.
Tim
