2 members (porsche, Dennys28),
93
Mod | | | Forums66 Topics128,051 Posts1,055,766 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Has anyone done it? Just had my front brake drumss, hubs and backing plates cleaned and derusted. I'm sure ZR with clear coat will work, just curious if anyone else tried it.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used Eastwoods brake drum coating (epoxy paint) it is pretty nice stuff and holds a nice glossy black finish. So far it is holding up great. Tim | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | ZR is really good for areas which you can't remove all the rust. If the rust is removed, I would use a high temp paint for the drums do get warm.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I pulled my drums off my toyota 6 years ago, before I had new rims put on. I poof-canned them in the driveway and last time I had the wheels off they still looked good. 162,000 miles and counting. Im just finishing up the drums on the COE and plan on doing the same thing, I may use a high heat paint this time. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Ive been using Duplicolor high temp engine paint on some small parts, such as linkages, radiator shell etc. the black paint comes in various degrees of gloss, and goes on nice and smooth, I can get good mileage from one can, costs about $6 a can. Will probably do my backing plate, perhaps the front end parts(tie rods, axle) with the Duplicolor when the time comes.
Mike | | |
