5 members (Hotrod Lincoln, Stovebolt48, sron48, TUTS 59, MRMEROTH11), 68 guests, and 1 robot.
Topics128,052
Posts1,055,770
#419750 06/04/2008 11:39 AM
Has anyone done it? Just had my front brake drumss, hubs and backing plates cleaned and derusted. I'm sure ZR with clear coat will work, just curious if anyone else tried it.
I used Eastwoods brake drum coating (epoxy paint) it is pretty nice stuff and holds a nice glossy black finish.
So far it is holding up great.
Tim
1952 Chevy Shortbed
Photos in Photobucket
ZR is really good for areas which you can't remove all the rust. If the rust is removed, I would use a high temp paint for the drums do get warm.
Craig
I pulled my drums off my toyota 6 years ago, before I had new rims put on. I poof-canned them in the driveway and last time I had the wheels off they still looked good. 162,000 miles and counting. Im just finishing up the drums on the COE and plan on doing the same thing, I may use a high heat paint this time.
My 1953 Chevrolet
1947.1 Gallery
Ive been using Duplicolor high temp engine paint on some small parts, such as linkages, radiator shell etc. the black paint comes in various degrees of gloss, and goes on nice and smooth, I can get good mileage from one can, costs about $6 a can. Will probably do my backing plate, perhaps the front end parts(tie rods, axle) with the Duplicolor when the time comes.
Mike
