| | | Forums66 Topics128,129 Posts1,056,695 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Needed to get a set of these for a buddy's truck. The ones that seal the ball housing to the transmission. In the past I have bought rubber ones but all the suppliers now tell me they can only get cork like the originals. Anyone have another source? There is a Fel-Pro number listed by some of these suppliers but it is not good. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Classic Parts has some:
Part #91-905 $17.95 3-speed Part #92-111 $12.95 U-joint/ball joint set. | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | olblu; Did you try American Classic? When I did my tranny rebuild, I bought their kit for the longbed and the ball seals were rubber. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Will try them. I emailed Jim Carter 3 days ago with a question about the material but never received an answer. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Bill, try Felpro #ES 72843
That kit has the various shim gaskets and the rubber seal that slips into the joint and compresses around the torque tube. | | |
