4 members (Wayne67vert, Wally / Montana, moparguy, Pete1946), 130 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#418995 06/02/2008 4:49 AM
1 Offline
Well I thought I had the brake problem fixed on my 51 I adjusted the clevis Rod between the master cylinder & booster and the front brakes ain't hanging up anymore and also ran brake lines to the rear disc and it's now got brakes all the way around but... When I step on the brakes the pedal almost go's to the floor and it doesnt come all the way back up ? I have to use my foot to bring it back up !
I ask a few buds and read on http://www.mpbrakes.com/technical-support/troubleshooting.cfm and they said that it could be that my Booster is bad.
Any one have a idea on whats going on now ??? HELP ! This is driving me crazy.
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
You do have a spring pulling the pedal back up right?
If original it goes forward to a C shaped bracket inside the frame about under the steering box, should have the clutch pedal return spring on one part, and the brake pedal return spring on the other.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
1 Offline
Its a firewall mounted power booster/master cylinder & pedal assembly, I thought about a spring, But why is it going almost to the floor ? You think it still has some air in the lines ? I was thinking about buying a power bleeder so I can do it by myself or breaking down and take it to a shop BUT....IF I can take care of it myself I would rather do that
Todd
Todd,
Try bleeding the brakes again, sounds like you still have air in the lines that is letting the pedal travel to the floor.
1952 Chevy Shortbed
Photos in Photobucket
1 Offline
Yeah, I going to bleed it again, That's what I was thinking too... You think that's why the pedal isn't coming all the way back up also ?
I'm thinking you might need to re-adjust the pushrod after you're sure all the air is out of the system. I made the mistake on my '62 of over-adjusting the pushrod on my M/C,and had to re-adjust it a little at a time until I had everything where I liked it.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Todd,
just a thought, how much pressure do ya get back on your pushrod when you push on it?? there should be a good amount of force pushin back at ya with no vacume on the diaghram, if there isnt maybe your booster has bought the farm???..the diaghram alone should push your pedal back up some.
but with no air in the lines the pedal shouldnt go to the floor, unless you have your pushrod way to short.
1952 Chevy Shortbed
1 Offline
Tim, I think my booster is shot.. Its like pushing on a brick, Ive never been really happy with it from the very first time, I bought a new one (Plus it gave me a reason to get a cool chrome one) grin and it should be here in a few days.
Todd
Atta Boy Todd!...nothin like rationalizin gettin SHINEY STUFF!..hehehhee...hope it fixes her up for ya..keep us posted.
Tim
1952 Chevy Shortbed
