1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#406766 04/26/2008 8:05 AM
I
I Offline
I may have a chance to go pick up my great uncles old dumptruck. It is a 800 mile trip one way. I believe it is a one ton or maybe a ton and a half. My dad doesn't know. I do know that my great uncle built the dumpbox for it himnself. I was wondering if anyone could give me an estimate of how much it would probably weigh. I know that without seeing a pic it is hard to guess but hoping for some ideas. My car trailer has only a 7000 lb rating. I have a new Duramax to pull it with so that is not an issue. Thanks
Both my 1 Tons are in the 6000 pound range.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #406874 04/26/2008 7:50 PM
In either case a 7K GVWR trailer is too light for such a long journey. Better get a 12K rated trailer or have it hauled.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I
I Offline
I just talked to my dad and he said it is eight lug axles and 700-18 tires and wheels.
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor.
1953 2 ton parts truck Long Gone
1957 GMC LCF On 75 Cadillac Eldorado Frame
Updated Feb 2021
Carhauler trailers I've rented at U Hall won't carry that much weight either. Whatever you get, be sure it has brakes.
~Jim
I
I Offline
A little history of the truck. My great uncle had it stored in the garage for probably 25 plus years then about 5 years ago my uncle got it out and put plates and such and was driving it. Well my cousin has it now, but I am going to get it. How much would be a good starting price to offer? I have no idea what else is wrong with it, if anything.
Updated Feb 2021
I
I Offline
Well against the popular advice I pulled it home on my trailer. I only lost one tire/wheel. Ended up not paying for it, my cousin doesn't really have any use for it. It has an updated drivers door, one with a wing window. The original is still there, stored in the garage. I will probably get it next time I am back up there. The front of the hood has a little dent, and there is a small scrape down the drivers side. The only rust through I have found is on the floorboard on the drivers side. The back window is cracked but still in place.
I am hoping to get some time to see if it still runs. It is supposed to. May be a great IRWIPI story.
Since I don't have a 6 volt charger would it hurt anything to try to jump it with a 12 volt truck. I am probably going to just leave it 6 volt instead of upgrading to 12. When I figure out how to make an album just for this truck in my photobucket I will post a link.
Updated Feb 2021
I
I Offline
http://s46.photobucket.com/albums/f129/Ibendcars/dumptruck/
I think this is a link to my dumptruck album.
Updated Feb 2021
Nice truck! thumbs_up The engine can be started with 12 volts, but don't crank it too long as to burn it out. I ran my old GMC suburban that way for over 5 years and sold it with the same six volt starter.
I noticed the engine is a later 235, check the casting numbers to see what year.
What's with asking the questions and then ignoring the answer? You're lucky that you only lost a tire! dang
Nice truck! , I bet it was a long haul home with that beast on a trailor...lol
1952 Chevy Shortbed
Photos in Photobucket
Great truck! Depending how long it's been since it was last run, don't be in a rush to start it without doing some prep work. Use fresh gas and check everything prior to starting. A little work now could save you some headaches later.
Bruce
My Trucks
Stuff I Collect
Nice looking dump bed. Your great Uncle did a fine job on it. I think it's great you were able to keep it in the family, and I love the price you paid. Submit a story and pics to the gallery - it would be another fine addition. Oh - nice to meet you, too. thumbs_up thumbs_up
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #417155 05/27/2008 1:28 PM
Looks like a nice truck. Like Bruce said take your time in starting it. Along with fresh gas pull the plugs and squirt a little oil in the cylinders and remove the valve cover and oil the valve stems and rockers.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
I
I Offline
I didn't ask IF I COULD PULL IT I only asked what it might weigh. I knew it would be a little overweight. It was a deal where I kinda had to leave right now to go get it. The local rental store was already closed, and I don't think they allow there trailers to be pulled out of state anyway. I put heavier rated tires on my trailer last time they were replaced.
Yes it is a later engine. The original seized up one is still sitting in the corner of the garage back home. Where is the casting number on the motor??
Updated Feb 2021
IBenDcars,
Interesting truck. One of the pictures of the engine compartment shows what appears to be a belt driven hydraulic pump and a firewall mounted sump. There is a lever attached to the pump that goes through the firewall into the cab. Is that a covered fuse box nestled up next to the sump tank?
Lots of fun stuff to figure out and play with..good luck and thanks for the pictures. thumbs_up
Stuart
Cool truck!! And the price was right, too!!
By all means, use fresh gas when you start it--either from a container, or else clean the tank. You would not believe the havoc that old gas can cause. Been there, done that!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
24601
I ran my '39's starter on a 12-volt battery for years. The problem is with the rest of your electrics -- 12 volts will certainly fry the gas guage and sending unit (assuming they still work anyway) as well as the other guages.
Check the wiring, though. On the older, non-running trucks, the wiring is usually a fire waiting to happen.
Good luck!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
jdl Offline
IbenDcars, you can go to Walmart and get a 6v/12v battery charger for $30. I had to do that because my charging system seems to have something wrong with it.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #417834 05/29/2008 2:06 PM
Nice Truck, 800 mile trip, I bet that burned up some Petro
Birge
1952 Cheverolet 3600
http://www.flickr.com/photos/bilge77/
Nice truck. Wish my 48 was that nice
Now boltless but looking
1951 F-1 350/350
1965 Mustang 355 glide
1971 F-100 401 fe it hates me
1972 Maverick 302 c4
