Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TexasFarmTruck, Pre '68 Dave, Shade Baby, Dakota Bob), 157 guests, and 3 robots.
Topics128,277
Posts1,058,442
Members48,490
#414382 05/19/2008 4:46 AM
I have my truck down to the frame and suspension. I used a gasket scraper to get most of the dried muck off. I had planned to use a wire brush on a grinder and get the next layer. Then I wanted to sandblast the rust spots and hard to get places.
While wire brushing I noticed a satin black sheen. I am under the impression from looking under my fenders that someone sprayed something like diesel fule on it to rust proof it. I think it worked pretty well. In any event, I took a rag with some lacquer thinner and it wiped right off.
Does anybody have any suggestions for cleaning this off. I have thought of using the thinner in a metal pan with either a rag or heavy steel wool and rubber gloves of course. My work are would have to be well ventilated or I will push it onto the driveway.
Any other thoughts. I don't think that simple green will cut nearly as well.
Todd M #414438 05/19/2008 1:04 PM
I'd have it sandblasted.
Bruce
My Trucks
Stuff I Collect
The first thing I do before blasting is pressure wash. You need to get as much grease and oil off before blasting or you run the risk of contaminating the metal. If that happens, your paint will fisheye or have adhesion problems. After blasting I get it primed right away with self etching primer.
Builder #414466 05/19/2008 2:13 PM
Todd,
the best thing I think I did when I started my project was to have my frame Steam Jennied, man it removed all the yrs. of gunk and in all the little hiding places, after that you can inspect it and decide on blastin or just preppin it for some POR15 or whatever.
just my 2 pennies.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #414473 05/19/2008 2:30 PM
Ex Hall Monitor
Ex Hall Monitor
Ditto, ditto. grin Either pressure was or steam clean. Like Builder said, if you drive the contaminants into the metal by blasting first you'll never see the end of the fisheyes and/or peeling paint.
Tiny #414820 05/20/2008 3:04 PM
buy a case of easy off oven cleaner
let it stay on the frame a day dance
spray on more over whats there
hose off
hi pressure degreaser
wash
paint
done wink
Jim & Caroline
Wow, Thanks for all the responses. I had not thought of oven cleaner. My wife was thinking that we could use a pressure washer to wash the siding on the house. Maybe that could be a useful power tool addition.
