2 members (Kilted54, UtahYork),
72
Mod | | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I finally started to prep the cab floor today with the por-15. I bought a 6 pack of 1/2 pint cans because I did not know how much I would use at a time, and I did not want to waste any. I used 2 of the 1/2 pint cans and this is what I was able to cover.
Entire Floor Fire wall, Underside of dash, Inside of Air Plentum box (cowl area)
Tomarrow I will flip the cab and do the underside. And the engine side of the firewall. I used a cheap disposble brush and painter mixing cup, I left 1-2 hairs in the paint, but I'm putting in a rubber mat so no one will see them anyway. Right out of the can it flows real well and I expect not to leave any brush strokes on the firewall. But I will use a better brush. I hate buying one for 5-10 dollars for a one time use, but I don't want any hair on the firewall. I don't thnk cleaning the brush will work that well.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | modelman: I personally like the stuff! Just don't breath it!! I also understand about the hairs.....got a few on my chassis but what the heck, it gives character to it! I like ordering it in the smaller cans which I will do next time! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Just put the brush in a ziplock bag with some xylene and put it in the freezer when you are done, and it should still be serviceable when you come back to it as long as you don't wait for more than a few days.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Hey Thanks 4OTF, Where did you learn that trick from? Insted of Xylene, would laquer thinner work? | | | | | Joined: May 2007 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 95 | If the hairs bother me, i use the other end of the brush to help dig it out, then continue painting. Anything that will see sunlight has to be topcoated.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can use whatever thinner is compatible with POR-15. It keeps moisture out of the brush and the ziplock keeps air out of there. Be careful that it is compatible with the bristle and handle material, though, or it can melt plastic eventually.
I learned that trick from a friend who is a high end house painter, and I use it when I'm doing projects that require a paint brush or roller. I keep my latex paint rollers individually in big zip locks until I am done using that type of paint. It lasts for months between uses that way.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'm with you on the small tin option, I bought the quart tin,I re-sealed the lid after use and a couple of days later I could hardly get the tin open again! :mad: It's as hard as nails! I found a little goes a long,long way. Tried an experiment with a scrap piece of metal. I 'attacked' it with 40 grit sandpaper and it stood up really well! Great stuff! I've covered my entire chassis,underside of my cab,cab fender wells,inside of the roof,the back of the dash and the rear of the cab behind the seat with under 3 pints! Brilliant!  It dries to a lovely gloss,shame a lot of it won't be seen! Jock. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | How much direct sunlight effect this anyway, I am doing my frame and some of the areas will get occasional sinlight, will this turn the por milky?
Ed | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | '''How much direct sunlight effect this anyway, I am doing my frame and some of the areas will get occasional sinlight, will this turn the por milky? ''' YES THIS stuff does NOT like sun..... PAINT THOSE AREAS W/ RUSTOLIUM OR ??? BLACK ''' I re-sealed the lid after use and a couple of days later I could hardly get the tin open again! It's as hard as nails! ''' :mad:  RESEAL THE LID W/ DOUBLE LAYER OF SURAN WRAP  I use cheap brushes and pick out the bristles when they are in the paint. mine is just a daily driver and i don't care much about that issue.  i mostly did small parts except the inner fenders and rad support were my bigger pieces.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | In your opinion how far up the firwall should I go with the Rubberized coating? I figure about an 2" area should be OK?
Jake | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Regarding the sunlight issue,I painted a tow hitch on my work truck about a year ago,the finish of the POR-15 has stood up to most things including the rock salt our roads dept. throws on our roads every winter! :mad: The gloss shine has deteriorated somewhat but the overall condition of the paint is still good. As others have said,to maintain a good gloss you should overpaint the POR-15.They also manufacture a chassis paint suitable for this application.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | Paint stores will sell or give you new pint or quart cans. I aways have a few to empty what ever is left in a gallon can. Used glass jars will work as well. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Paint brushes are like most any tool. There are good ones and there are look-alikes. I have found if I get a good brush it doesn't shed hair like my cat, cause its annoying to have to pick hair out of the paint. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | A tip i learned, re-sealing the can with plastic wrap, say a half full can. Tuck the plastic wrap down into the can to the surface of the paint so no air is in contact with the paint, put the lid on. Also be sure to clean any paint out of lip of can. | | | | | Joined: May 2008 Posts: 10 New Guy | | New Guy Joined: May 2008 Posts: 10 | Couple of comments about these type of paints ( I rep two different brands but they are the same type).
Use a foam brush. They don't leave hairs and no lines and leave a smooth finish.
Don't open the can. Punch holes in the top of the can (very top, not in channels). Pour what you need. clean top and then cover with duct tape. Keeps the air out and it won't harden on you.
If you use a hard plastic dish, you can reuse them after a few days. When finished, I leave the brush in the dish and because this paint won't stick to hard plastic, after it dries, all the paint lifts right out.
Clean and degrease completely. While this stuff does stick well to rust, if you haven't degreased it will peel off quickly. Same with dirt...won't stick to it.
As for sunlight, all manufacturers recommend their cover coat over these rust encapsulators for exposed areas. If you're just talking underhood/cowl, it will take years and years before you see a change because it doesn't get that much UV.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi JDH,I like the idea about puncturing the lid  That POR-15 is too expensive to waste! Thanks for the tip! Jock.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | the easy way to get the cover off is to put a piece of plastic wrap under the lid before you close it. comes right off and just throw the plastic away. | | |
