5 members (68ironhead, GRNHydra, Oswald, RLB, dt235sd), 130 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#41138 03/21/2004 4:06 PM
I am looking into doing the power steering conversion on my 51 ,3100. with the kit from clsssic performence products.Question, What kind of bracket set for pump to use?Engine is 235 with single pully driving alt and power steering pump.Has anyone done this?
I believe Patrick's has a kit.
54 3100 with 235
62 flatbed dump C60 with 261
The magazine "Custom Classic Trucks" has a tech article on that very same kit. Starting on page 66, they show all the parts involved. They show (in pictures!) eveything you need to do to convert. Looks like a sweet set-up.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Hey 48
Which issue was that? I'm interested as well for the 49.
It is in the May'04 issue I just got. It starts on page 66.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Not up on the Custom Classic Trucks web site yet.
Junior Member
Junior Member
You can find a story on power steering for your solid axle Chevy in the October 2002 issue of Classic Trucks magozine.
1951 Chevy 3600, 1996 Yukon, 2000 Road King
It is easy to take liberty for granted, when you have never had it taken from you.
http://www.stovebolt.com/gallery.htm
I have read most of the tech articles on power steering conversions but none mention conversion with a six cyl. Patricks has a bracket set up for installing a/c on235/261 sixes,possibly you can mount power steering pump instead of a/c pump? I am going to look into it. old navy 51...........
That is the one I was talking about. It solves where to put the belt. Another way would be to run the pump off the alternator with a double pulley.
54 3100 with 235
I ordered the mounting kit from patricks yesterday ,will mount power steering pump where they show the air cond compresser I might need to rework things a bit ,but everything should work ,Keep you posted on the progress. old navy ..................
Hey, Old Navy,
What was the outcome of Patrick's pulley? I want to do a P/S upgrade on my 59-235 so I'd like to hear from any body that has already done it. What pump did you go with etc?
