8 members (HandyAndy, Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series),
72
7
Mod | | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41138 03/21/2004 4:06 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I am looking into doing the power steering conversion on my 51 ,3100. with the kit from clsssic performence products.Question, What kind of bracket set for pump to use?Engine is 235 with single pully driving alt and power steering pump.Has anyone done this? | | |
#41139 03/21/2004 5:10 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I believe Patrick's has a kit.
54 3100 with 235 62 flatbed dump C60 with 261
#41140 03/21/2004 6:53 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The magazine "Custom Classic Trucks" has a tech article on that very same kit. Starting on page 66, they show all the parts involved. They show (in pictures!) eveything you need to do to convert. Looks like a sweet set-up. Scott | | |
#41141 03/23/2004 10:55 PM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Hey 48
Which issue was that? I'm interested as well for the 49.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#41142 03/24/2004 12:55 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It is in the May'04 issue I just got. It starts on page 66. Scott | | |
#41143 03/24/2004 2:47 AM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Not up on the Custom Classic Trucks web site yet. | | |
#41144 03/24/2004 2:47 AM | Joined: Jan 2004 Posts: 32 Junior Member | | Junior Member Joined: Jan 2004 Posts: 32 | You can find a story on power steering for your solid axle Chevy in the October 2002 issue of Classic Trucks magozine. | | |
#41145 03/24/2004 2:46 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I have read most of the tech articles on power steering conversions but none mention conversion with a six cyl. Patricks has a bracket set up for installing a/c on235/261 sixes,possibly you can mount power steering pump instead of a/c pump? I am going to look into it. old navy 51........... | | |
#41146 03/24/2004 3:17 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | That is the one I was talking about. It solves where to put the belt. Another way would be to run the pump off the alternator with a double pulley.
#41147 03/25/2004 11:12 AM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I ordered the mounting kit from patricks yesterday ,will mount power steering pump where they show the air cond compresser I might need to rework things a bit ,but everything should work ,Keep you posted on the progress. old navy .................. | | |
#41148 05/29/2004 6:28 AM | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | Hey, Old Navy, What was the outcome of Patrick's pulley? I want to do a P/S upgrade on my 59-235 so I'd like to hear from any body that has already done it. What pump did you go with etc?
