0 members (), 41 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#404200 04/19/2008 5:25 PM
RT1
Offline
I bought a big bolt from fellow bolter. My dumb question is. What is the little lever for on my shifter lever. It attached to the side of the shift lever with some mechanical linkage running along the side?
-R headscratch
It sounds like the lever you raise up, to allow the shifter to go all the way to the left and down for reverse gear.
1949 Chevy 6400
1931 Chevy Firetruck
Sounds right to me, if it is a pre AD transmission, or possibly a really early AD?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
R Online: Content
Whose big bolt did you get? Got any pictures?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Isn't this for a two speed rear end? Or am I thinking the wrong thingy?
Bruce
My Trucks
Stuff I Collect
RT1
Offline
From Ron Turchin it was for sale on the SBP. Says it is a 47...
Rons Pics
Look in my signature, Mapes already painted it to match my Rod...LOL
Cool truck! That is the lock out lever for the reverse. 1947s still came with the non-synchro transmissions. The 2 speed rear ends that use the switch on the shifter are more of a button that you pop up and down.
My 1953 Chevrolet
1947.1 Gallery
47 still was using under mounted dash switch for 2 speed rear as well. pointer on top would indicate high or low position. good luck
