7 members (Brian Moore, tclederman, Lightholder's Dad, jupitor, treegrower, GMCJammer51, J Lucas),
223
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | I bought a big bolt from fellow bolter. My dumb question is. What is the little lever for on my shifter lever. It attached to the side of the shift lever with some mechanical linkage running along the side? Thanks -R  | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | It sounds like the lever you raise up, to allow the shifter to go all the way to the left and down for reverse gear. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds right to me, if it is a pre AD transmission, or possibly a really early AD?
Grigg | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Whose big bolt did you get? Got any pictures? | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Isn't this for a two speed rear end? Or am I thinking the wrong thingy?
Bruce | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | Whose big bolt did you get? Got any pictures? From Ron Turchin it was for sale on the SBP. Says it is a 47... Rons PicsLook in my signature, Mapes already painted it to match my Rod...LOL | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Cool truck! That is the lock out lever for the reverse. 1947s still came with the non-synchro transmissions. The 2 speed rear ends that use the switch on the shifter are more of a button that you pop up and down. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | 47 still was using under mounted dash switch for 2 speed rear as well. pointer on top would indicate high or low position. good luck | | |
