| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | I should be getting My new windshield soon,I have replaced windshields in tractor trailers before so I have some experience,But have never put one in an old pickup.Any tips on how to go about it would help.Thanks | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | All you need is a new window seal, small diameter rope, silicone spray and a couple of extra hands to help. Install the seal on the glass, wrap the inner part of the seal with the rope and spray the seal with silicone. Set in place with the rope to the inside of the cab and have the extra hands applying pressure from the outside. Start pulling the rope so the seal flips over the flange of the cab while a helper follows you from the outside. It should go quick on a 65, the 63 and older trucks windshields wrapped around the A pillar and made it a bit more difficult to install. Good luck, Scott | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I prefer to use personal lubricant over silicone spray, it is water based and doesn't interfere with future paint jobs.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Please guy's, get away from this silicone spray! It's the work of the Devil!  I agree silicone sprays have their uses but not in this instance! I fit glass for a living and never use anything other than plain old glass cleaner. It wont 'hurt' the paint finish or the rubber! 4ontheFloor's right, silicone will contaminate your paint and may cause problems for any future paint remedial work! Good Luck Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | Just had all the glass installed in my 64 Suburban Friday. Well worth the $150. Included windshield with molding(needed many hands!), rear door one piece gaskets, rear quarter windows with one piece gaskets, and removal and reinstallation of my second(slider) windows that already had rubber on them, but I'd forgotten to put the cushion pads under the frames. They used window cleaner. | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I've got a guy that does this glass stuff for a living and he's been here at the house on several occasions installing my glass. Never anything more than a good quality glass cleaner and his rope with a window stick. Just last week, watched him put a new glass in an 80' LUV, start to finish...12 minutes. My bill...$100. Best money ever spent for the prevention of rectal irritation in my opinion. | | |
