8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I've had a bottle of Sta-bil for probably ten years, and each season I dutifully put some in the tanks of all the gas tanks I'm putting into seasonal storage. You know, lawn mowers, snowblowers, the old truck, etc. Recently I thought, "How long does Sta-bil (or any gas stabilizer) last?" I went to the Sta-bil website http://www.goldeagle.com/sta-bil/faqs_stabil.asp and there in the FAQ's was the answer: "2 years after the bottle has been opened, provided it has been tightly capped and stored in a cool, dry place." Wow! Now I wonder if I've been doing anything at all to help my engines start up after storage! They all have started without problem, though, so who knows? I thought this might be of interest to other stovebolters. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I was going to put a bottle of it in my tank for winter storage but at $13.00 per bottle I said forget it. (You thought the price of gas was high!) I have used AVGAS instead over the years and it works as well or better. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Guess I am one of the lucky ones. I have never used any additives for winter storage,and never had any fuel problems. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I didn't use it much until my garden tiller GUMMED up and I spent an afternoon working on it. The killer was while I was working out of town the carb on my 37 gummed up while setting for some time and I had to rebuild the carg. You can get SMALL bottles of it at most parts stores. I know Advance Auto parts has it in smaller containers. I DO use it and since I have not had any problems. It doesn't take much but what a big difference it will make if you "park" something for sometime. Just a spoon full of sugar helps the medicine go down....Uh, I mean a spoonfull of Sta-bil keep your engines starting! | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | All you need for a "stabilizer" is an ounce or two of diesel fuel. I bought some stuff at AutoValue, before I stopped going there, that was C$16.95 a liter (about a quart). Its supposed to do all sorts of wonderful things like "stabilize" the fuel, clean injectors, "improve gas mileage", seal the valve guides, and whatever.
It smells just like diesel, so one day I put some on a piece of paper and torched it. Lo and behold it smoked and smelled just like diesel. Suspicions comfirmed! I've been using diesel as a stabilizer for years.
So as for these fancy-nancy chemicals - BAH! HUMBUG!
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When I wrote above that it was $13.00 a bottle, that was for a small bottle. Probably a pint size. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | works good for me i used to have truoble with generators and mowers but iv been useing it and what a defference when you get it out and it starts right up iv even added it to a gummed up motor and let it set and it cleaned it up to running conditin im sold | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I use it every yr. Especially on my Bass boat that thing got 6 Carbs and I havent had any problems in the spring when I put it in the water, So even if StaBil is pricey it still wouldnt be near as much as trip to the Envinrude Doctor for my V-6 outboard. So I will continue to purchase it every yr. Tim | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | My pop runs Stabil in all his gas cans he uses for the lawn equipment. | | |
