4 members (Southerntruck, Gray_Ghost, Guitplayer, Joe H), 186 guests, and 0 robots.
Topics128,192
Posts1,057,351
Members48,469
Not much progress between the weather and other responsibilities but I did manage to get some parts cleaned.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Got the underside of the bonnet painted and bolted it together. Then it was lay out all the bolts, screws, fixings, and work out where they belong and what i need to buy. This happens when you totally strip your truck. I had them in a drum.
Nothing. I was in your neck of the woods last week, Woody, playing golf in the Pinehurst area, and didn't get back until late Saturday. The weather wasn't great, but we managed to get five rounds in. However, the weather is getting much better here, and I'll begin my spring work on the truck today or tomorrow.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Hood ("bonnet" wink ) bumpers installed, glove box door bumpers installed, new/correct choke cable installed, and got a $180 quote on a complete exhaust system
AND hauled 6 young trees from the nursery to the house!
Worked on some wiring problems, then took her for a long ride!!
Wrestled a new ringgear onto my flywheel. Now, I gotta put everything back together.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Worked on the brakes. Got the front lines run, now working on the rear.
Robert C.
I'm a Genius in the making.
1950 3600
Got the window felt in the drivers door,put my front signals on,worked on some of the wiring,patched another hole in the floor,and tried to find where water is getting in the cab(what else would you do when it's raining?),and started getting all the adjuster pullys loose on the seat frame.
And now I'm looking at tires,OUCH $600.00 without tubes
Put some brake fluid in, found out the master cylinder is leaking on the 53 6400. Decided that the gas was getting low so I had to force myself to go for a ride to the gas station. Amazing how a 2 mile trip takes an hour, but one heck of a sugar pill after a long winter.
I worked on my power steering conversion for about 9 hours and still I'm not done. Fun stuff, but I'm getting there,once I get the Pitman arm on I'll be in good shape. I think I need to move the steering box a little for the Pitman arm to fit. Hopefully it will be worth the effort and expense.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
I got my truck out of winter storage, it's been sitting since December. Had a heck of a time figuring out why it was so reluctant to start. It didn't seem to have any spark. Fiddled with the points. Recharged the battery several times. It turns out that while I expected the carb to be dry, instead I succeeded in flooding it. Finally it caught. Since then it's been running great.
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Got the rest of the shackle and spring bushings out of the '39 GMC this weekend.
With the grass growing now I had to get the blade off the tractor and get the mower on as well as doing the spring maintenance on the 2-53 GM Diesel in my John Deere 435.
Also wound up doing the brakes on my suburban and the daughter's camaro.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
Not too much this weekend. I did enjoy watching my university put the hurt on UCLA in the Final Four. grin
I did swap the thermos housing for a billet straight 45 Degree. My crate engine came cocked left and my radiator exits from the center.
~Jim
First I switched out my Rochester Carb for the YF on the 216 in my 52. It fired up the best it ever did. Then I discovered it was sucking air through the throttle shaft, so I am back to the start point on that one.
Drove with Scott D- to our Wisconsin Bolt lunch gathering in my 46. About a 50 mile ride all told. Learned about some rear end options from TC and king pin instructions from Randy B-. Got back and dismantled my front end to replace the king pins. This was REALLY overdue. Got everything cleaned and prepped for reassembly when I get the axle back in a day or so.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
I spent Saturday running up to the north end of Baltimore to pick up my new bandsaw, then spent the rest of the day assembling and getting it set up. Made a few test cuts around 7 that evening and pushed to the back of the shop so I could get something done on the Burb.
I drilled the undersized hole on the caliper bracket out, went to the parts store and bought the correct size grade 8 hardware then reassembled the front left hub and disc assembly. That was work left over from last weekend.
I was about to tear down the right side to do the same when I got a bug to try salvaging the sway bar brackets instead. Here is what I started with old bracket
I had a busted bolt to drill out on both brackets and I had to weld up the shock mount hole as they had both been torn up pretty bad. Since one end of the hole still with the broken bolt had good threads after my drilling operation I ran a bolt through it from the top, cut it off and peened it in place to create a stud. like this
There a couple other photos there if you can find them. Anyhow that is as far as I got... two good brackets ready for paint.
I converted the 53 216 to 12V and put in a new rear main seal, and I did a little sanding on the 56 cab.
Spencer
Apprentice
Apprentice
One word, Fabrication.
Had to Work so .......
I could only "Drive My Bolt this past weekend" cool
Couldn't work on her!!!!!
I did however on Monday weld on "glasspacks" (or pack) to the ol 59. She sounds great... for a REALLY STOCK Bolt! thumbs_up
Cliff(Va-Room)59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
I spent Friday and Saturday at a little slice of gearhead heaven on earth at the Portland Swap Meet. It is one of the largest on the west coast. Walked for hours upon hours looking at trucks, cars, parts and vendors. Actually met Jim Carter, nice guy. Chevs of the 40's had a complete modern AD frame next to a complete new 5 window cab with display of all sheet metal for sale. Yes, you can now build a completely brand new AD, if you have a spare $30-40K in your pocket. Got a few things for the '50 and some for the '64 Pontiac, including a new truck floor. Spent Sunday hacking out the truck floor on the '64. All and all a great weekend.
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
