| | | Forums66 Topics128,186 Posts1,057,317 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Since it's no longer the weekend of the 22nd - 23rd let's start a current week.
I stripped my removed fenders, blasted and painted the headlight buckets and pulled the 216 out of my '51 | | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | ..moved to this weekend Put a new lightswitch in yesterday, tried to adjust one of the headlights, but the plastic clip is broken. Also cleaned out some leaves from the air vent and attempted to fix the drivers side door latch. Put new points and condenser in today. Got some more leads on a place to take the truck to get body work and paint.
Here's a picture of the truck at it's new home with the F-105. Also with primer over the bare metal. I call it Cletus. http://www.flickr.com/photos/22133917@N06/2374731287/ | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Today I managed to finish installing the TV cable. It may need a little adjustment but I won't know until it get the truck running and test it out. http://good-times.webshots.com/photo/2028510450099708909oythOz_________________________
~Jim
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Apache, I can tell you are ready for the show season,  | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Big Chevy... Beautiful workmanship... as a welder I'm very impressed with what I see. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks Woody, I guess that semester at community college paid off.
~Jim
| | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | today i finished my boxing plates and all the filler peices and welded it all together finally.
gotta love old trucks
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Got my newly painted bed set on the frame! WHOOOHOOO!...now if I dont have to put in a 60+ hr week like last week maybe ill get somethin done! Just a Tip, make sure ya got lottsa help to set a bed with a 1/4 thick steel plate floor welded in!...OOOH MY BACK! Tim | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | Spent the weekend working on mowers and a garden tiller. I had planned on changing the oil in my '59 Viking, but ran out of time. I will try and do that this week.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Replaced the leaking oil pressure Guage oil line, added a voltmeter...cut 2 lawns. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Thanks Woody, I guess that semester at community college paid off.  Sure did! You can always tell how much care goes into a project by the qualitty of the welds. It's the first thing I look for in a custom and invariably if the welds are fine the rest of the build is too. If not... well, you know the rest of the story. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | got to shampoo rugs and watch the snow, | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks Woody, that means a lot coming from a pro.
~Jim
| | | | | Joined: Oct 2007 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 94 | I didn't get much work done on my truck, but I did go out and get parts. I went to Maple Grove's spring flea market on saturday. Instead of coming home with what I went there looking for (28 spline posi), I came howe with cab corners, driver's side windshield, cab patch panels, and upper and lower rad. supports. All for about $65. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Still hooking up the TPI.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | All I did was drive my '65... my thumb is still sore from the shock replacement the weekend before.
| | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | I primed and painted the frame of the 58 from firewall forward and hung new springs and shackles. I bolted up a rebuilt axle but had issues with the disc brake set up that was on it, subject of another post. I also welded up the inner fenders where fatigue got the best of the hood hinge attachment area. Filled all the extra holes (and then some) made over the years while I was at it. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | So, dburban, where's your pictures. Gotta have proof here...
~Jim
| | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | So, dburban, where's your pictures. Gotta have proof here... look for 'em tomorrow ...I'm running out of gas  Hope this works, I have a few before and after shots here.
| | | | | Joined: Sep 2007 Posts: 12 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 12 | Put the battery back in the '54 3100 truck-it has been stored all winter in a friend's garage, took out the bars of Irish Spring soap and smelly dryer sheets used to keep mice from nesting inside the cab and under the hood...removed the boxes of mice posion on the floorboards, turned the key, pulled out the choke, stepped on the starter twice, waited 2 min. for the blue smoke to clear, pumped the breaks to be sure there was still something there and took off for home.... | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Got the hood and fenders off this weekend. A lot of scraping and cleaning ahead. Cleon | | | | | Joined: Mar 2008 Posts: 28 Apprentice | | Apprentice Joined: Mar 2008 Posts: 28 | I picked up my new 49 Chev AD 2 ton on Sat morning, now i just have to get it running! (sorry i introduced myself in Bigbolts) Everything looks good except I have to wire up the ignition and starter. Anyone know where to find a wiring diagram? I am so exited to get this ol girl goin and on the road, shouldn't take much. I also helped my buddy fill and sand on his 50 shoebox (just frenched the tail and headlights) Then party time on Sat. night for my friends b-day (mmmmmmmmm chilli and beer!)
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | You can find the wiring diagram in a manual, and if you don't have one, try American Classic Truck Parts, or Jim Carter, or another one if you know it. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I installed a pair of 1986 Corvette shorty headers on my 350 conversion upside down so that I can still use the stock steering. Then I cut and welded J-bends to reroute the exhaust back down through the back corners of the engine bay, where there's more room. It really looks trick, kind of like a racing boat motor.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Didn't get much done, I usually work Saturdays (and when I don't, I'm usually out of town). I did get a new exhaust put on my S10 Blazer driver, and I went to the Super Sunday swap meet in Indy. Other than that, I didn't get much done.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | I edited the old post but I guess you need to reply to get it to the end of the trail.  I posted a few pics of my weekend work here. Pay no attention to all that spaghetti, all the wire becomes history once I get the front end back together.  | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Great work there dburban... Nothing more satisfying than to work hard and accomplish some goals and move closer to the finish.
~Jim
| | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | Couldn't agree more, working on the truck is great therapy. Its important to keep an eye on that last part "move closer to the finish" else you end up working just to have something to do and finishing is no longer the goal. I have a 64 El Camino that was 3-4 months away from being finished for years cause I kept finding new mods to make (it was fun). Then I changed jobs, moved and put it on hold for a few years. Then along came the Suburban. Did I mention my wife bought the Suburban and supports all these (bad?) habits.
So I set goals: make the Burb watertight, make it run (and stop), then make it street legal. After all that, think about the mods and fun stuff but keep it on the road so we can enjoy it. | | |
