7 members (dt235sd, Bill Hanlon, bnauman, Ridgeback, Otto Skorzeny, 1955 1 Series, Chris's 46 / 515), 79 guests, and 2 robots.
Topics128,175
Posts1,057,115
Members48,463
Hello knowledgeable ones, I was told a 52-54 chevy car that came with a power glide trans, would have had 355 gears or there abouts, so a good swap to my 52 pu, to get better / lower rps, at highway speeds, vs the 411's in it now. My question is, does anyone know what the gears are in a 52-54 chevy car that would had had the 3 speed std trans ?
thanks
I believe 53-54 with std shift had a 3:70. I ran the 3:55 powerglide car rear under my 46 half ton for a long time, easy swap.
1946 1/2-Ton Chevy
Y
Y Offline
52-MOBIL, I wanted to do the same thing on my 53 AD, but found out the rear axle/torgue tube is shorter and narrower. It came out of a 54 two door car. So I suggest you get out the tape measure. I think it will work on the 41-46 trucks.
Riding in the Passing Lane
That's the way I understand . The powerglide rear end will fit the older models but not the AD's.
1972 Chevy c10 Cheyenne Super
I've had a few drive shafts shortened but can they be lengthen?
~Jim
