10 members (baldeagle, cmayna, Woogeroo, Hotrod Lincoln, SmalltownTRKGuy, Ponchogl, walter74, 3 invisible),
348
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | Hello knowledgeable ones, I was told a 52-54 chevy car that came with a power glide trans, would have had 355 gears or there abouts, so a good swap to my 52 pu, to get better / lower rps, at highway speeds, vs the 411's in it now. My question is, does anyone know what the gears are in a 52-54 chevy car that would had had the 3 speed std trans ? thanks
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I believe 53-54 with std shift had a 3:70. I ran the 3:55 powerglide car rear under my 46 half ton for a long time, easy swap. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | 52-MOBIL, I wanted to do the same thing on my 53 AD, but found out the rear axle/torgue tube is shorter and narrower. It came out of a 54 two door car. So I suggest you get out the tape measure. I think it will work on the 41-46 trucks. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That's the way I understand . The powerglide rear end will fit the older models but not the AD's. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I've had a few drive shafts shortened but can they be lengthen?
~Jim
