9 members (Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L., 55shaker, Wally / Montana, Uncles51),
83
Mod | | | Forums66 Topics128,075 Posts1,056,003 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 26 New Guy | | New Guy Joined: Sep 2001 Posts: 26 | Is there any paint or coating system that really lasts for exhaust manifolds, or is it best to just leave them rust? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used Eastwoods S.S. exhaust coating, so far I cannott comment as to how it work on the road, will be finding out soon and will post to its performance.
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I used Por-15 product and got two results. I sandblasted both and baked them after painting. The one that still looks good is probably due to the fact that I haven't fired up the motor, the other one showed rust in the first year, but I ran that motor. I talked to a Por15 rep and he said sandblasting was not the best way to prep the metal for their product. I sprayed the Exh. pipe with rattle can HiTemp paint and it did as well as Por15...showing some rust. Moral here is, Don't fire up the motor or find a better product. I'm looking for that product. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I've never tried this but I will try on something eventually. Sounds like a great idea. It's about half way down the page under manifolds. Dan | | | | | Joined: Nov 1995 Posts: 5,721 24601 | | 24601 Joined: Nov 1995 Posts: 5,721 | I used the Eastwood aerosol spray hi-temp manifold paint and it looked great until it got wet -- then it rusted.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is the pertinent information from Dan's link, above: Spray Manifolds Gray
Exhaust manifolds may not be the ultimate in flow, but they fit right, they usually seal well, and they look stock.
Unfortunately, they also usually look like hell, thanks to rust. You've probably tried to paint them only to have it burn off and look worse. Try this: Pull the manifolds out, strip them down to clean iron, either in a sandblast cabinet or with a wire brush, then get a can of spray graphite lubricant and follow up with a soft rag to rub it in. The spray is powdered lead in an oily binder, and it will make the manifolds look like fresh, bare, cast iron, but it won't burn off. When it eventually gets to looking shoddy again, get out the spray can and touch it up.Sounds like good old high-quality wood-burning stove blackening; or, Calyx Manifold CoatingDoes anyone have first-hand experience with this type of product? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I used Eastwoods on mine also. It burned off in about a year of use. So I sent my fentons out to get hot-jet coated. After three years they still look like the day they were coated. I think it cost me around $80 but it's worth it, not having to touch up the manifolds in the engine compartment when they start to look bad. Just my $0.02 George | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What exactly are you refering to George? Hot-jet, is that a brand name, or do you mean aluminized or metalized or powder coated? Can you be a little more specific as to what the process or product or vendor is/was? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | tc Have you used the Eastwood product or graphite? Sounds like a great idea.........Am waiting on someone to try......Come on .....You know you wanta.....Ok I'll try it on sumtin. Dan | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I don't know how long it would last but someone here on the bolt suggested or had tried the old wood stove polish from a hardware store and if I remember right it worked nice. Just depends on your funds at the time! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dan,
I am thinking of using the Calyx product on some Fenton headers this spring (unless I get them coated by Jet-Hot or AirBorn Coatings).
Tim | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I have the info somewhere around here from Jet-Hot, and if my memory is still working, I think they wanted nearly $265 to coat my exhaust manifold on my 230. I thought it to be kinda high. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I use Eastwood cast iron gray on all my exhuast manifolds with good results. A pint will do many manifolds. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Back in the brown-shoe-days we used to wipe a hot manifold down with hydraulic fluid. It has the same effect as "seasoning" a cast iron skillet... and it works. Just freshen it up every so often. | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I've used the Calyx product with extraordinary results. Bought mine from Eastwood but other suppliers have it and it's a little cheaper.
I've used it on intake manifolds, exhaust manifolds, steering boxes, and master cylinders. I removed and media blasted some. Others I just wire brushed a little and applied the product with a toothbrush leaving the part in place on the vehicle. At $20 for a small jar I thought it was a bit pricey but after everything I've done I still have over 2/3 of the jar left. Just make sure you work the product into all the little crevices and continue to brush to a nice mellow shine.
I previously had exhaust manifolds powder coated but it was pricey and they didn't come out looking nearly as nice and natural. Plus you can touch up your work later if a problem arises (hasn't happened yet). | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Arch,
Thanks for the information. It's always nice to hear from someone has has first-hand experience with a product. I am going to give the Calyx product a try on a set of Fenton headers that I had painted (brand new) with Eastwood's cast iron gray (for manifolds) but they show rust. This will be a cheap any easy experiment.
Tim | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh I just gotta stir the pot a little Tim. I've been following a thread over on the VCCA chat on engine paint, not what color this time but what was painted. According to the "experts" the intake and exhaust manifolds and clamps and gaskets and bolts were all painted the engine color. This was based on archived photographs and first hand from one of the former heads at the GM proving grounds. Which means that, for the exhaust manifold to be showroom original, it should be "caramelized dark gray"!!! Denny Graham Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Denny, What are you saying...It isn't right unless it looks like the day it left the assembly plant? If that be the case, why ? Does it look better ? I find so many faster , easier, cheaper, ways the manufacturer used that does not look good I can't help myself from making an improvement to make something look better. Take for instance the splash of inspection paint all over the truck frame and driveline. Red, grn,yellow paint and blu on the rear axle of some. I realize why its there but I don't think it makes a resto job look better. Then there's the sloppy way adhesive was applied at the factory to W/S and to hide all the adhesive so it is not seen would not be factory like. I'd rather it did not show and do a neat job, but there again....it's not factory like. And the list can go on and on about how the factory did it. It's all in what you want....make it look crappy like the factory did, or do it nice like they should have done,but were not willing to do because of cost. Dan
| | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Actually the gray painted exhaust manifold after a short time on the road turned white and then eventually rusted.
34 & 35 trucks are the greatest
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey guys, can I take my toungue out of my cheek now??? I was just kinda pokin some fun at this one!!! Denny G
| | | | | Joined: Sep 2001 Posts: 26 New Guy | | New Guy Joined: Sep 2001 Posts: 26 | Here's a little follow-up. I tried Calyx Manifold Dressing (type that in Google, you'll find it) about a year ago now and it is great stuff. Gives the cast look you want, stays soft, won't burn off or crack, and real easy to redo a few spots if you need to. Great stuff.
I've driven about 1000 miles with it on. Only problem is when wash truck and water gets on (drips thru hood hinge), and let set a few days after, some little rust spots form. Probably because I didn't rub in the Calyx real good at first. But only takes about 10 minutes to make look like new again, right there on the engine, not unbolt the manifold. I've just learned to start up engine after wash, so manifold dries off quickly. Looks like new a year later. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I agree 46 panel. I rubbed it in/on my manifolds after I blasted them and they look really nice. I haven't started the engine up yet but they look nice. Thanks for the tidbit on water spotting. I'll make sure I get her good and hot right after a wash job. that stuff goes a long way to. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | This is "two years into Calyx" all I did one day was wire brush what I could reach with a wire tooth brush. On the rebuild I'll "glass bead blast it" before applying the Calyx. This stuff has to be some sort of graphite since it is still rubbing off after a couple of years. Here a picture of the manifold off the truck during the teardown this summer (2010). http://www.pbase.com/dennygraham/image/124991344/large I really like it better than paint as it does look a lot more original than paint. Denny Graham Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | thanks for confirming it Denny. Your manifold still looks good. Its good to know I made a good decision!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
Has any water touched the manifold since you applied the Calyx Dressing? Have you sprayed any water on the manifold, to clean the engine?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No Tim, I treat water like acid. I figure the old gal has seen enough water and mud in her life time. I have gotten caught in the rain a few times when I was away from home. Like I said, all I did is a quick wire brush one day and them rubbed in the paste. I never reapplyed it after the first time. Still like to know just what's in it. Denny Graham Sandwich, IL
