0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 4 New Guy | | New Guy Joined: Dec 2006 Posts: 4 | Hey yall, I'm having trouble with my brakes not releasing. I changed wheel cylinders thinking that had to be it, but that was not the prob. Master cylinder is not that old, Somtimes they release and sometimes they don't. weird. One guy at work said the inside of the old hoses might br braking down and little peices of rubber stopping things up. I have bled them and bled them. What do yall think? Any suggestions? thanks. 1965 stepside, drums all the way around. old style single master cylinder. | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | It would be worth checking that you still have some free move ment on the pushrod that goes into the master cylinder, if the master cylinder recovery port gets closed off through the pushrod not having free play, it can cause the brakes to bind on.
Stuart. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If the hoses are more than a few years old, replace them no matter what they look like on the outside. They swell up on the inside.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Those are all good suggestions. Also make sure the emergency brake cables are not sticking. They can hold the shoes off the anchors. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Quick easy check-When they get stuck just crack the bleeder loose,If they release that means the hoses are bad.If you just do one side and the other loosens up also it may be the hose on the pumpkin,but replace all of em anyway so you don't have any problem's down the road.Tom | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I had a similar problem with my 40. I found that I needed to add more play to the pushrod. | | | | | Joined: Dec 2006 Posts: 4 New Guy | | New Guy Joined: Dec 2006 Posts: 4 | thanks evetyone, they do release if i crack a bleeder, gonna change hoses for sure, if that don't wokk I'll yank the master cylinder and check the push rod.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup as stated above, my rubber line from the frame to the rear ..was clogged completey shut it would let enough pressure through to apply brake but not let the fluid return hence locked up rear brakes. replaced that line all is well
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Did you order the hoses or pick them at a local parts store? I think NAPA might carry 'em for anyone else looking. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Big Tee, I picked up my replacement at NAPA , had my old one with me an we went in the back an the parts guy let me search through the shelf till i found the one that matched. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | SW Radial,
Do you have the NAPA part number? It probably fits a lot of other trucks, too.
Thanks | | |
