2 members (Southerntruck, TooMany2count), 72 guests, and 2 robots.
Topics128,089
Posts1,056,116
Members48,434
#392648 03/24/2008 10:42 PM
Hey yall, I'm having trouble with my brakes not releasing. I changed wheel cylinders thinking that had to be it, but that was not the prob. Master cylinder is not that old, Somtimes they release and sometimes they don't. weird. One guy at work said the inside of the old hoses might br braking down and little peices of rubber stopping things up. I have bled them and bled them. What do yall think? Any suggestions? thanks. 1965 stepside, drums all the way around. old style single master cylinder.
It would be worth checking that you still have some free move ment on the pushrod that goes into the master cylinder, if the master cylinder recovery port gets closed off through the pushrod not having free play, it can cause the brakes to bind on.
Stuart.
If the hoses are more than a few years old, replace them no matter what they look like on the outside. They swell up on the inside.
Paint & Body Shop moderator
Riding in the Passing Lane
Those are all good suggestions. Also make sure the emergency brake cables are not sticking. They can hold the shoes off the anchors.
1972 Chevy c10 Cheyenne Super
Quick easy check-When they get stuck just crack the bleeder loose,If they release that means the hoses are bad.If you just do one side and the other loosens up also it may be the hose on the pumpkin,but replace all of em anyway so you don't have any problem's down the road.Tom
I
I Offline
I had a similar problem with my 40. I found that I needed to add more play to the pushrod.
thanks evetyone, they do release if i crack a bleeder, gonna change hoses for sure, if that don't wokk I'll yank the master cylinder and check the push rod.
Yup as stated above, my rubber line from the frame to the rear ..was clogged completey shut it would let enough pressure through to apply brake but not let the fluid return hence locked up rear brakes.
replaced that line all is well
1952 Chevy Shortbed
Photos in Photobucket
Did you order the hoses or pick them at a local parts store? I think NAPA might carry 'em for anyone else looking.
1946 Chevrolet 1/2-ton
More pix on Photobucket
Big Tee,
I picked up my replacement at NAPA , had my old one with me an we went in the back an the parts guy let me search through the shelf till i found the one that matched.
1952 Chevy Shortbed
SW Radial,
Do you have the NAPA part number? It probably fits a lot of other trucks, too.
