3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 12 New Guy | | New Guy Joined: Jan 2008 Posts: 12 | Hi Guys and Gals. Working on my 51 3600, Both cab fronts were rusted out really bad in front of the doors. Purchased 2 patch panels as well as the inner braces. Went to work and drilled out all the spot welds and melted the lead from the seam. I have the new panel in place and here is my delema. Do I just weld the whole seam grind it down and put a light skim of bondo to finish, or should I hire someone to relead the seam and do not weld it. Thanks for your Help Robin | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I am sure someone will chime in on the best approach, I would prob. just mig it in and skim coat it, Leading the seam would last a lot longer but be a bit more of a hit on the checkbook. It all depends on your tastes, I prefer the lead myself that is what I payed for on my panels ...an it was not cheap to get it done by a professional with the expierience if you have access to one. just my thoughts
| | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | How original are you wanting to stay? Are you looking to win shows with originality? or just a personal play truck? If the latter, I wouldn't bother with the lead. Mig is a bunch easier, faster, and will look just fine. However, if you are going for a show truck, every bit of originality counts. Just my $0.02 Gator >|--|~ | | | | | Joined: Jan 2008 Posts: 12 New Guy | | New Guy Joined: Jan 2008 Posts: 12 | Nope shes is just going to be a resto mod. Not to much original front end is a Mustang II Ford rear end 350 SBC 700R Tranny. I was hoping I could get away with welding. Robin | | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | Weld. Cheaper, faster, and stronger. Laterz, Gator >|--|~ | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Do I just weld the whole seam grind it down and put a light skim of bondo to finish, or should I hire someone to relead the seam and do not weld it. Regardless of what you use, lead or plastic, you have to weld the seam. Lead is just a filler and ads no structural strength. If it were me, I'd weld it and mud it. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Plastic is todays modern lead filler, and it's lighter and more user friendly, Scott | | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | I came across a product called " Liquid Metal " and then the labels were changed to " Plastic Metal " same stuff, different name. It comes in a tube for around 8 bucks. You can sand it, drill it etc. Easy as heck to work with. The stuff was great. All made up, no hardeners etc. Before I applied that I used " Rust-Mort " It stops rust from spreading. Hope this helps. Now that i found this product, its bye bye to bondo for me. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I'd go easy with any one-part filler. They dry through liquid evaporation and will probably shrink as a result of losing their volume. Spot putty is a good example... too thick looks good for a couple months and until it's done shrinking. | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I agree with you Czechman. One body shop I worked in, the owner came around to all our tool boxes, collected tubes of spot putty from any of us that had it and threw it all away, then told us if he found any again we were fired. It is basicly thick primer in a tube and will shrink. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
