| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 27 Apprentice | | Apprentice Joined: Mar 2008 Posts: 27 | Trying to find door glass - pass. side for my 1950 3100 5 window. Think I may have to pull the cracked glass and have a new piece cut using the original as a template. Does anyone know of a supplier for OEM glass for these model trucks? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | your local glass shop should be able to hook ya up,use your glass as a template,It will be far cheaper than ordering replacement glass from parts suppliers that may or may not fit right. Flat auto glass is pretty cheap to have cut. | | | | | Joined: Dec 2004 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 58 | classic parts of america has a good selection of glass. dave
1954 custom 1-ton (1 of a kind) | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Had my 4t6 door glass cut locally a couple weeks ago for $45 a side. I got the soft green tint. Welcome to the Bolt! Good luck and have fun! Dan | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Get ahold of "Wrenchbender Retired" from this forum. He's a local from your area and often parts out trucks. Did you check out the swapmeet section yet? He may be in there too, Scott
