10 members (Bill Hanlon, TooMany2count, 66flea, Hotrod Lincoln, BC59, Charles in CA, Gdads51, 68ironhead, 2 invisible), 93 guests, and 3 robots.
Topics128,032
Posts1,055,519
Members48,425
#389437 03/18/2008 2:59 AM
will a 1995 caprice chassis work under a 1952 3100 truck?
How wide is the Caprice?
~Jim
1969mm
It's a parimeter type frame not a rail type. It would too wide a track width too I would think,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #389525 03/18/2008 5:21 AM
The Caprice is perfect for a 63, no shortening or narrowing required. This means it is too wide for your 52 without modifying. Here is my 63 short wide with a caprice frame.
http://s32.photobucket.com/albums/d41/coilover/
First click on "page 3" and then scroll down to "63 on cap..."
Evan
coilover #389629 03/18/2008 3:30 PM
You don't have the frame for your 52?
~Jim
I think he is looking for the easiest switch to a 350 and disk brakes, and he has the Caprice available...
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #389658 03/18/2008 4:21 PM
Bigchevy-54tow: He still has the body (nice one) on its original chassis. I talked to Bennie last night on the phone and he has a 95 caprice with a tuned port and all disc brakes. He would like to sit his body on the caprice chassis as a lot of the running gear stuff is missing on the 52.
Since he's a stovebolt member I told why not ask the pro's!!!!
Bennie works pretty late so it'll probably be tonight before he comes back on here.
I figured "somebody" had done it!...or tried to! I know he'll appreciate the info.
Achipmunk #389728 03/18/2008 7:06 PM
With time and money, anything's possible!
Robert C.
I'm a Genius in the making.
1950 3600
Achipmunk #389937 03/19/2008 2:38 AM
THE WHEEL BASE IS THE SAME
coilover #390850 03/21/2008 1:20 AM
Do you have any build photos of this frame swap?
I'd love to see them.
Zeke
