| | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 3 New Guy | | New Guy Joined: Mar 2006 Posts: 3 | will a 1995 caprice chassis work under a 1952 3100 truck? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Mar 2006 Posts: 3 New Guy | | New Guy Joined: Mar 2006 Posts: 3 | | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's a parimeter type frame not a rail type. It would too wide a track width too I would think, Scott | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The Caprice is perfect for a 63, no shortening or narrowing required. This means it is too wide for your 52 without modifying. Here is my 63 short wide with a caprice frame. http://s32.photobucket.com/albums/d41/coilover/ First click on "page 3" and then scroll down to "63 on cap..."
Evan
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You don't have the frame for your 52?
~Jim
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I think he is looking for the easiest switch to a 350 and disk brakes, and he has the Caprice available... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bigchevy-54tow: He still has the body (nice one) on its original chassis. I talked to Bennie last night on the phone and he has a 95 caprice with a tuned port and all disc brakes. He would like to sit his body on the caprice chassis as a lot of the running gear stuff is missing on the 52. Since he's a stovebolt member I told why not ask the pro's!!!!
Bennie works pretty late so it'll probably be tonight before he comes back on here. I figured "somebody" had done it!...or tried to! I know he'll appreciate the info.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | With time and money, anything's possible!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2006 Posts: 3 New Guy | | New Guy Joined: Mar 2006 Posts: 3 | THE WHEEL BASE IS THE SAME | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | The Caprice is perfect for a 63, no shortening or narrowing required. This means it is too wide for your 52 without modifying. Here is my 63 short wide with a caprice frame. http://s32.photobucket.com/albums/d41/coilover/ First click on "page 3" and then scroll down to "63 on cap..." Do you have any build photos of this frame swap? I'd love to see them. Zeke | | |
