1 members (TexasA&M48Truck),
190
Mod | | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I’m getting ready to take my wheels to have them cleaned up. So today I removed the tires from the wheels. To break down the tire from the rim of the wheel I let the air out then drove over the tire right close to the rim with my other pick up. A trick my Dad taught me years ago. Has anyone else done this?? | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I've never done it, but I've heard of it back in the 70's from old timers. Samantha | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yep, works great. Can also use a 2X6 or so board as a ramp placed on the tire but not the rim, start to drive up it, same results.
On a stubborn one I ended up using the bush hog on the back of the tractor when the truck was not enough, it is a really heavy one, just lowered the side of it on the tire to pop the bead off.
Grigg | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I used to do it that way. Now I'm rich enough to pay someone the few bucks to do it for me and old enough to enjoy watching...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I've done that trick, then used 2 tire irons to work the tire off the rim. I then patched the tire, put it back on the rim with the tire irons, and set the tire to the bead with a 12 volt compressor. It's amazing what you can accomplish when you use the resources at hand. | | | | | Joined: Nov 2004 Posts: 2,401 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,401 | I also, have run over a tire or two in the past to break the bead loose. I have also used a bumper jack. I just positioned the base of the jack on the tire right next to the rim, and started to jack up the truck.
More than one way to skin a cat!
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Good god, try breaking down these 20" 2 piece wheels... I worked at one on and off for days before I got anywhere. Once the lockring was off I rolled it onto a piece of firewood and used the log splitter to break the rubber off the rim. Then I gave up on that when it didnt work and I cut the bastard with the sawzall... | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i have use the driving on trick. but rustednuts, i like your idea, i never though about using our log splitter, i bet it would work with smaller rims/tires 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | You bet! I really like the log splitter idea, though. Mounting larger tires can be weird, too. I remember seeing an old timer put a couple of shots of ether inside a tire and throw a match on it! Not one I'd want to try, but he had a fleet of logging trucks and said he did it all the time. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | I remember seeing an old timer put a couple of shots of ether inside a tire and throw a match on it! Not one I'd want to try, but he had a fleet of logging trucks and said he did it all the time. My dad would do that to, i think he probably learned it from my grandfather, anyways everytime he would do that, and id be around to see, he would immediately tell me never to try it, of coarse i had to but i watched him closely and knew to only use a small amount of ether. Anymore i just pay to have a tire changed. the local garage only charges me $5 per tire.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've used the front end loader on my tractor. | | | | | Joined: Aug 2005 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 73 | I broke down all my 20" tires with the grubhoe side of a smaller pick.It worked great for them all except one and I sawzalled that one off after alot of swearing lol | | |
