2 members (baldeagle, 78buckshot), 20 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#388985 03/17/2008 1:25 AM
Any recommendations as to where to new glass for my 37? There use to be a place here that would cut flat glass for old vehicles but they closed up many years back.
1937 Chevy 1/2-Ton
wasat again #388993 03/17/2008 1:33 AM
wasat: I believe just about any glass place that carries it will be able to cut it. For my 37 I checked out a place that cut mirrors and plate glass for stores.....turns out they did a lot of auto glass as well. Take in your old glass for a pattern. If you do not have one I think JimCarter sells the pattern(??) For the side windows I took my old ones over there and they took the old glass out and put in the new glass for me.
###Be sure they mark the position of the glass in the piece it fits in so the new glass goes back in exactly the same place or you may end up with it in where it will not roll up to fit the door just right.
Hope this helps.
EDIT: I just noticed your in S.C. If you have a Kaspasi around close I know they do it. Hey, are you close enough to come to a stovebolt gathering of US LOCALS in Spartanburg JUNE 14th??
Achipmunk #389108 03/17/2008 10:12 AM
I have to Agree with Alvin, Most any glass shop will have vehicle glass on stock ..that you can have cut as long as ya have a pattern.
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #389155 03/17/2008 3:32 PM
I replaced all glass except the corner glass in My 52.
The glass shop had the original type glass in stock, and it was
tinted also...I took in one side of the windshield, one door
glass, and the back glass...It all fit great.. Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
