4 members (Cletus1950, Uncles51, dt235sd, Gray_Ghost), 106 guests, and 2 robots.
Topics128,174
Posts1,057,048
Members48,458
Does anyone know where i can get 20 or 22.5" one piece 6 lug wheels for my 62'GMC 4000
This Tech tip
http://www.stovebolt.com/techtips/wheels/
Although there is a lot of good info in it, it does not cover your 6 lug options, in the future it will.
Open the Tech Tip, then click on the link for the Accuride Wheel Catalog.
The wheels you are looking for should be the ones on page 18, part number 28157, check the bolt pattern to be sure.
These 22.5" wheels can be bought new from most any big truck tire shop.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I see this company advertising in one of the trades. I am not familiar with them but they claim to have a complete line of steel wheels. I have not visited this site either but here it is:
www.centurionwheels.com - 570-353-2729
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
my truck has 9" wide wheels and the accuride ones are 6.75 otherwise i think they are the same.
Sure they are 9" wide? what size tire were your running on them?
The 6.75" width is measured at the tire bead seat, so actual rim with is more than that, and obviously the dished center sticks out even more on one side too.
Grigg
---All pictures---
the tires are 10.00X9.00
That's confusing too, I was expecting something like 8.25X20 tires?
Do you have a picture or two
Grigg
never mind they say 9.00X20.00 typed it wrong the first time
Then a good replacement wheel and tire combo would be the new Accuride wheels, or used ones at 6.75" width (same as new). And 10R22.5 tires.
Grigg
---All pictures---
I was just at our local junk yard and theres a 55-57 GMC 350 series with 2 speed rear end thats running single piece 20" or bigger 6 lug Budd wheels. Not that it would help you unless you felt like going for a drive...
Jeff
My 1953 Chevrolet
1947.1 Gallery
Jeff
If they are on a 55,6or7 they are 22.5s 20" are tube type and 22.5" are tubeless and all one piece wheels are tubeless
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
