| | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | Does anyone know where i can get 20 or 22.5" one piece 6 lug wheels for my 62'GMC 4000 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | This Tech tip http://www.stovebolt.com/techtips/wheels/Although there is a lot of good info in it, it does not cover your 6 lug options, in the future it will. Open the Tech Tip, then click on the link for the Accuride Wheel Catalog. The wheels you are looking for should be the ones on page 18, part number 28157, check the bolt pattern to be sure. These 22.5" wheels can be bought new from most any big truck tire shop. Grigg | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I see this company advertising in one of the trades. I am not familiar with them but they claim to have a complete line of steel wheels. I have not visited this site either but here it is: www.centurionwheels.com - 570-353-2729 | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | my truck has 9" wide wheels and the accuride ones are 6.75 otherwise i think they are the same. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sure they are 9" wide? what size tire were your running on them?
The 6.75" width is measured at the tire bead seat, so actual rim with is more than that, and obviously the dished center sticks out even more on one side too.
Grigg | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That's confusing too, I was expecting something like 8.25X20 tires? Do you have a picture or two Grigg | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | never mind they say 9.00X20.00 typed it wrong the first time | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Then a good replacement wheel and tire combo would be the new Accuride wheels, or used ones at 6.75" width (same as new). And 10R22.5 tires.
Grigg | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I was just at our local junk yard and theres a 55-57 GMC 350 series with 2 speed rear end thats running single piece 20" or bigger 6 lug Budd wheels. Not that it would help you unless you felt like going for a drive...
Jeff | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I was just at our local junk yard and theres a 55-57 GMC 350 series with 2 speed rear end thats running single piece 20" or bigger 6 lug Budd wheels. Not that it would help you unless you felt like going for a drive...
Jeff If they are on a 55,6or7 they are 22.5s 20" are tube type and 22.5" are tubeless and all one piece wheels are tubeless | | |
