2 members (DIY.MechanicMike, Stovebolt48), 76 guests, and 3 robots.
Topics128,179
Posts1,057,064
Members48,460
Apprentice
Apprentice
ive got a big bolt its a 48 1 1/2 ton. i can make a pump work and run the lines but my question is on the steering box what can be used and how can i set it up with my original steering column i can fab up some brackets if someone has an idea of the direction to head in. thanks
I don't think it's possible to retro P/S to your original steering box and column. I replaced my column and box to achieve P/steering.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I can't remember which mag I saw it in, but they did the mod to an AD 1/2 ton and kept the original column (well, most of it). They installed a new box and cut the column just above the old one. The column sleeve was cut again a little higher. A phenolic bushing was used to center the actual steering shaft in the sleeve. A modern u-joint and shaft connected the old shaft to the new box. If you can find a box which will drive your steering, I'm sure some system like this will allow you to keep your original wheel and column.
That article was either in Classic Trucks or Custom Classic Trucks. They do that mod all the time on 1/2 Tons. They usually use a rebuilt steering box from an 80's Toyota Truck and a custom Pitman arm. If you pick up a copy, I think that you will find a supplier that advertises a kit. The steering column is cut as stated but the net result is a purely stock truck inside the cab.
It is coming up the time of year where magazines publish a complete listing of their articles for the year. This is usally done in Dec ot Jan.
1951 1 Ton Completed
