3 members (dt235sd, GMJim, 2-Ton),
136
Mod | | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38346 11/14/2004 1:49 AM | Joined: Nov 2004 Posts: 29 Apprentice | | Apprentice Joined: Nov 2004 Posts: 29 | ive got a big bolt its a 48 1 1/2 ton. i can make a pump work and run the lines but my question is on the steering box what can be used and how can i set it up with my original steering column i can fab up some brackets if someone has an idea of the direction to head in. thanks | | |
#38347 11/14/2004 2:47 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I don't think it's possible to retro P/S to your original steering box and column. I replaced my column and box to achieve P/steering. Scott | | |
#38348 11/15/2004 8:09 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | I can't remember which mag I saw it in, but they did the mod to an AD 1/2 ton and kept the original column (well, most of it). They installed a new box and cut the column just above the old one. The column sleeve was cut again a little higher. A phenolic bushing was used to center the actual steering shaft in the sleeve. A modern u-joint and shaft connected the old shaft to the new box. If you can find a box which will drive your steering, I'm sure some system like this will allow you to keep your original wheel and column.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#38349 11/15/2004 10:44 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That article was either in Classic Trucks or Custom Classic Trucks. They do that mod all the time on 1/2 Tons. They usually use a rebuilt steering box from an 80's Toyota Truck and a custom Pitman arm. If you pick up a copy, I think that you will find a supplier that advertises a kit. The steering column is cut as stated but the net result is a purely stock truck inside the cab.
It is coming up the time of year where magazines publish a complete listing of their articles for the year. This is usally done in Dec ot Jan. | | |
