0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I'm in the midst of taking all of the components out of the doors of my '50 AD 3100 for the rebuild. I have taken all the screws out of the door latch mechanism and removed the door handle. The whole mechanism is wobbling around inside the door and moving up and down, but just won't come out. Is there a trick to getting these out of the door? For clarity sakes, this is the part I'm trying to replace. Door Latch | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | If I'm not mistaken you have to remove the glass & the channel it slides up & down on to get them out...Joe | | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | All that is already removed. The only thing left in the door is the latching mechanism. It won't slide up and down because of the piece that sticks out of the door that contacts the striker plate. It'll move forward in the door slightly but then gets jammed (kind of like SpaceBalls). Won't go any further. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | HMMM ...with my window & guide strip removed the latch fell right out after i removed the screws. | | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | Don't know. Maybe I just need a bigger hammer. I'll keep working on it. Thanks. | | | | | Joined: Jan 2003 Posts: 48 Apprentice | | Apprentice Joined: Jan 2003 Posts: 48 | Don't use a bigger hammer! I did that last weekend and cracked a weld in the latch mechanism. I was working on the passenger door latch. I had the same problem. It turned out that inside the door skin where the striker protrudes there is a flange or another layer of sheet metal. In my case the striker was hanging up on it and would not slide out of the hole. I finally stuck a knife blade in between the latch and the inside flange and bent it in a little so I could lever out the latch. Of course the latch then fell down inside the door which added to the fun.
Good luck!
Wilber
Don't read the directions, that'd be too easy.
| | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | Thanks, Wilber. Sounds like we are definitely having the same issue. I couldn't get a knife blade in there before but I'll keep trying. I look forward to dropping the latch into the bottom of the door for a new challenge. | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | RedGreen: I had the same problem and it was sovlved as 47 did. Just fiddle with it and it will come out. Cursing helps. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I think the shop manual describes the process and has pictures also. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | TOO FUNNY!  | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Are you working on the pasenger side? If so, have you removed the lock? If you haven't, the lock pin might be rusted into the latch and holding it in the door.
If that's not it, call me. I can provide some excellent "workin' on the truck" curse word combinations.
:hammering: | | |
