7 members (TexasFarmTruck, Otto Skorzeny, MOTOXFAMILY, Phak1, kurbside bolter, 2 invisible), 157 guests, and 3 robots.
Topics128,268
Posts1,058,378
Members48,485
#370320 02/04/2008 3:46 PM
I'm in the midst of taking all of the components out of the doors of my '50 AD 3100 for the rebuild. I have taken all the screws out of the door latch mechanism and removed the door handle. The whole mechanism is wobbling around inside the door and moving up and down, but just won't come out. Is there a trick to getting these out of the door?
For clarity sakes, this is the part I'm trying to replace.
Door Latch
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
RedGreen #370338 02/04/2008 4:54 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
If I'm not mistaken you have to remove the glass & the channel it slides up & down on to get them out...Joe
#370720 02/05/2008 2:26 PM
All that is already removed. The only thing left in the door is the latching mechanism. It won't slide up and down because of the piece that sticks out of the door that contacts the striker plate. It'll move forward in the door slightly but then gets jammed (kind of like SpaceBalls). Won't go any further.
Webshot Photos
RedGreen #370724 02/05/2008 2:37 PM
HMMM ...with my window & guide strip removed the latch fell right out after i removed the screws.
1952 Chevy Shortbed
Photos in Photobucket
Don't know. Maybe I just need a bigger hammer. I'll keep working on it. Thanks.
Webshot Photos
RedGreen #370883 02/05/2008 9:23 PM
Apprentice
Apprentice
Don't use a bigger hammer! I did that last weekend and cracked a weld in the latch mechanism. I was working on the passenger door latch. I had the same problem. It turned out that inside the door skin where the striker protrudes there is a flange or another layer of sheet metal. In my case the striker was hanging up on it and would not slide out of the hole. I finally stuck a knife blade in between the latch and the inside flange and bent it in a little so I could lever out the latch. Of course the latch then fell down inside the door which added to the fun.
Good luck!
Wilber
Don't read the directions, that'd be too easy.
Thanks, Wilber. Sounds like we are definitely having the same issue. I couldn't get a knife blade in there before but I'll keep trying. I look forward to dropping the latch into the bottom of the door for a new challenge.
Webshot Photos
RedGreen #372550 02/08/2008 7:04 PM
RedGreen: I had the same problem and it was sovlved as 47 did. Just fiddle with it and it will come out. Cursing helps.
I think the shop manual describes the process and has pictures also.
Originally Posted by Tangovino
Cursing helps.
TOO FUNNY! grin grin
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #379281 02/24/2008 3:00 AM
Are you working on the pasenger side? If so, have you removed the lock? If you haven't, the lock pin might be rusted into the latch and holding it in the door.
If that's not it, call me. I can provide some excellent "workin' on the truck" curse word combinations.
:hammering:
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Moderated by  ndkid275, Phak1
