3 members (IHPWR, David Bush, Gdads51), 130 guests, and 3 robots.
Topics128,142
Posts1,056,472
Members48,441
#370441 02/04/2008 9:15 PM
I'm looking at a 1963 Chevy pickup in an auction. It's pretty beat up, but it has a 6 cyl engine that may be just the ticket to replace my dead 216 in our '49 4600.
Here's the question: How do I tell the difference between a 230 and a 235 in a truck that I can only look at and not take apart?
All help is appreciated.
Jim
The valve cover is an easy place to start. A 230 or 250 will have 6 bolts holding it on. A 235 will have 4.
A 230 or 250 will have the distributor all the way to the front on the pass. side.
235 is midway back on the pass. side.
And the side cover(pushrod cover) is 2 pieces on a 230/250.
235 is one piece.
Seein as how the motor is in a 63, its most likely a 230/250
Probably, but make sure first. I got given a 64' with a 235 in it.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Certified Bolt Nut
Certified Bolt Nut
always remember that just because it has a motor in it now, doesn't mean it was the original engine. My 65 has a 250 (not avaliable until 66)...so take the year of the truck into account, but do the research above to find out for sure.
